Samsung Note Edge
petricnah
Extra protection without compromise sensitivity, why not!
frankly speaking, i don understand why the need to put screen protector? :s11:
isn't the screen made of simi gorilla glass?
scratch proof?
putting screen protector will not lessen the screen's sensitivity meh ? :s11:
nightkids7089
oic....so far, which are the best protector in the market?
i believe doesn't have much choices for note edge right?
i have read complaints about some protectors leh....:(
xrubiksx
scratch proof?
sensitivity may not be significantly affected i guess. but on the other hand, it can help to tank any possible scratches. so i guess its quite worth to have one? haha! at least i feel more comfortable having one.
renfred89
scratch proof?
gorilla glass is never scratch proof. only scratch resistant leh.
of cos screen protector will never decrease sensitivity because of the capacitive touch screen. If you refer to resistive touch screen, then maybe i concur with you.
angel99999
I do think the healing shield does interfere with the touch screen a little, such as double tap on instagram to like a picture takes more effort or tries to accomplish, that said, it gives people a peace of mind of their phones.
Once scratched on the glass, can never erase the scratch away, imo healing shield is a poor SP, and we can only await better ones made by spigen or other well known sp manufacturer.
renfred89
the instagram double tapping is actually a bug on the app.. not the touch sensitivity on your phone..
austy
Guys, how is your 4g network on ur Edge? I keep getting 2 bars with 3g.
Sent from GAGT Android App
wiccawizzards
4G as in your data?
Because if I am not wrong, data and its signal strength is not measured on a mobile phone.
austy
I am using 4g data and it seems to be having weak signals or sometimes no coverage? My fren's Edge also feels this way.
xphobic
Just pasted healing shield, not smooth at all, but a tradeoff before the edge get scratched
rudylili
Hi there,
Anyone know how to display battery level on the edge screen?
I miss Note S view window.
wiccawizzards
Wah I hoot a unit of this one. Frankly it is not that difficult to hold!
And apparently Samsung is giving out free flip cover when you buy it between 12 December 2014 till 11 jan 2015. 😀
wildpig8
This is from XDA : :s12:
I emailed iloome.com about the status of a tempered glass screen protector for the Note Edge and recieved the following reponse.
[From: iloome Support support@iloome.com
To: Me
Date: Dec 10, 2014, 6:20 PM
"Dear Valued Customer,
Thank you for your inquiry. We are working on it as we speak, and will be released sometime in January!
Thanks,
Brendon
iloome]
tminus
Recontract from telco got free cover also?
wiccawizzards
Starhub CS say dont have free cover wor.
Where u get ur phone from?
Have any link to share?
The CSOs on the phone will never know anything one lah. You will have to go down to the shop and ask.
I got mine from M1.
wiccawizzards
What I mean earlier was that the reception bars that you see on your phone. The one at the top left hand corner. It DOES NOT measure the data coverage of 4G.
Which Telco are you on?
