Samsung Note Edge
Kel1ng
So far this firmware seems very stable and fast comparing to the India firmware.
codling
The edge camera button is missing after lollipop. Jin sad...
The slomo and fps cam now embedded in modes...
Zioonlaw
Do you guy have goggle service running after updated to lollipop? my is running in background and it drain lot of battery.
royfrosty
Its definitely draining a bit. Set the location service to the 2nd option rather than high accuracy. High accuracy will draw more power.
Zioonlaw
After doing another round of factory reset, I can't seem to find google service running.
mbgeow
hi guys, where can i buy n paste the edge screen protector, mine came off after one mth of using it leh
Zioonlaw
I think most of the handphone shop sell edge protecter. Quite expensive though. Around 20-28 if I'm not wrong.
Do anyone know, is it every note edge protecter will have bubble on the left corner? The curve part. I changed quite a few protecter but keep getting the bubble. A lot of shop seller told me is normal there a bit curve
mbgeow
mine does not have any bubble on the left or curve side but just that after using for a mth the curve side protector came off.i paste mine at starhub shop, 38 bucks sia
rinotan
Anyone encounter 2 Horizontal Arrow indicating different direction as icon? How do I get rid of this icon?
Sent from Samsung SM-N915G using GAGT
Kel1ng
That is the icon for volte........why you wanna get ride of it?
pool7979
I still got a piece left from my 3 pack healing shield shield. Can let go man.
Anyway eh you guys how to pull the notification panel when phone is horizontal ma? Last time note 3 can. I notice note edge cant quite sometime ago but haven go around asking. Thanks man.
