Samsung Note Edge
royfrosty
Alright just finish installing the os and do a clean factory reset.
shavyshave
Suspended
Compatible with the gear s?
Kel1ng
Waiting for samfirmware to upload to their servers........was already on the India lollipop.....can't wait to flash local
derrickgoh
Strange it didn't auto download even though I set to auto update. Hope it doesn't screw up anything, most importantly NOT the battery life! :eek:
Wah sh*t the phone damn hot during the update and even now. Is that normal?!
royfrosty
Normal for a Sd805.
Now you know that sd processors especially 805 onwards it is extremely hot on load. Good thing Sammy is using their own 14nm tech as of now, which is the s6 is using.
Sd is too far behind.
And wait awhile. The phone takes time to update.
derrickgoh
Wah zhun boh? Battery dropped from 70% to 60% after the update? :eek:
Well lucky no massive drops thus far (touch wood). Dropped from 60% at about 4 pm to 53% now.
Kel1ng
It takes about a week normally for battery to stabilise after a major firmware update......do give it some time to settle down.
ritzboi13
My edge keep rebooting. It indicate google play services requires an update. Download halfway and always restart. Dunno wats wrong. Any of u experience this?
MIVEC525
My frd edge after update screen went blank? Any solution? Thanks!
Azuredrak
There seems to be a rare bug with the new firmware where browsing the Internet causes a Google search history to be remembered by the keyboard. The URL appears as a pop-up bubble to suggested term and doesn't go away from the keyboard, thus, covering most parts of it. (since search URLs are typically lengthy) This only happens in very rare cases, should not pose a problem for most users, just take note if you run into the problem.
Can't seem to reproduce it, but restarting the phone fixes it.
