Samsung Z Fold 7 AI ~ Thinnest! Lightest ~ et" Accessories!
Invisible1234
Guys, if I arranged for CompAsia to pick up my Watch 4 on 11 Aug, even though I have already received my Watch Ultra, nothing wrong to hold my Watch 4 longer right?
chari-men
Personally for my N3 I've pasted my own inner SP on top of the default one since day 1... No issues close to two years, if really need warranty claim I'll just peel off before sending it to SC.. but not sure for Samsung foldables will spoil the screen or not...
NeonX
just carousell for 1, ongoing price is 2150 also
My old fold 4 original SP start bubbling after a year, and had scratches after awhile. Just thinking if another layer can prevent bubbling and also easily replacable once its scratched up
you risk applying more pressure and stress to the inner screen leh, next time bubble then change ba
what case you guys using ah? I got the samsung clear case, feels weird to not have a front case on
RayOfLight
when folder is around 1 iphone pro max with ultra hybrid case thickness.. agak agak
what case is this? can share a close up pic of the usb-c port there? I am using ringke fusion case and the charging port there is quite sharp and I am used to holding phone with my pinky finger, so it's quite uncomfortable.
Amuroraysg
i got this weird problem on this phone with whatsapp..
the name for each chat are totally diff.. the number below to user a but the display name is user b..
all mess up not even 1 is correct...
uninstall app doesn't help anyone have this issue
Amuroraysg
Spigen ultra hybrid, the charging port cut out is taper..
Yuripa
Does it mean that high chance the blue shadow F7 will peel on the sides even with case??
Dunno. Hopefully not. Sse store salesperson that I chit chat with insist blue ZF7 will not peel.
Did you get your ZF7 with ss care+ ?
If yes, you can get free inner sp replacement once a year or 2x yearly iirc
I replaced my ZF6 inner sp for free last month at ss ps outlet
Collect on same day + no need to reset phone
Did you port over the data from iPhone?
So far I use smart switch from ss to ss phones no compatibility issues during data migration
