SCB SingPost/Spree Card
Trazora
Hello guys. May I know when the rebates will be credited? i.e I spent $700 in May. When can I expect the rebate. Thank you very much!!
You will see it in your next month statement.
Kcusts
On your statement date
Thank you for the reply. If it will appear in my next statement, it means that it will come in this month? Any idea if it's around the beginning for the month(which means the next few days) or sometime later? Cause I want to use the rebate to offset the bill first and then pay the reminding. As this is the 1st time I used this card.
I know that Manhattan's rebate will come in within the 3rd or 4th day of the month.
wts2013
u have IB, login 2-3 days after statement date (of your May spend), u shld see it posted
oceanicmanta
I tested & made a $10 SingTel payment via MySam.sg.
Called CSO and she confirmed the transaction is an eligible "online transaction" for 7% rebate.
Do let me know if anyone knows otherwise.
ska13a
why so mafan?
login singtelmybill easier
cbyen
My telco bills paid at mysam for past few months get the online rebates.
iadpotato
this card the terms changing on 1 July...
"Effective from 1 July 2015, you must charge a minimum amount of $600 to your Card within the statement cycle. Maximum CashBack awarded for any statement cycle is capped at $60 per principal card account. You will earn CashBack of 2% for supermarket and 0.2% on other selected qualifying retail transactions"
then i receive a mailer from them saying its based on posting date..... ???
so... if my statment date is 10th of each month... how ah? kinda confusing ley....
Trazora
For supermarket 6% till 30 Jun, 2% after that.
Min spend amount I take it as $600 for the statement ending in Jul, just to be safe
dreamyboy
The way I understand is if they posting is done by 30th June, then they will follow the old terms. Any posting done on 1st July onwards will follow the new terms.
For instance,
1. If you spend $800 on online spending before 30 June, you will only get a rebate of $50. Additional $10 rebate can only be earned from 1 July onwards.
2. If you spend $500 before 30 June, you will get the rebate (7%/6%/0.25%) as promised. Additional spending of less than $100 from 1st July will get nothing as the requirement for this portion of the month is minimum spending of $600.
I stand to be corrected.
ska13a
For instance,
same as what cso told me
in short i would use, max it prior to july and top up the difference of the max rebate in spending by the statement date to get full rebate
aren't all our statement cycle dates on 23rd?
my wife's and mine are. so we just use it to max before 23/06,then wait for July to do the spending for the new July cycle rule.
