SanDisk or Kingston..
Why no samsung?
now microSD card so cheap the bare minimum u should get is class 10 if you are buying new MicroSD
The Class also helps to differentiate. Class 10 is not the normal standard. They are all standards. The only diff is that CLASS stops at 10MB/s of minimum read write. UHS GRADE has only 2 - 10 and 30. So it technically is just a rating. Many cards with UHS grade 3, typically has double the minimum required. So my benchmark helps you to differentiate that.
A quick Q, how many of you guys encrypt your SD card on your phone? Does it affect performance?
It is a tough one, but depends on your needs. Kingston, Sandisk and Lexar are good brands to look at.
SanDisk is faster or Kingston is faster?
now you can still find class 4 micro sd card in the market ah?
from which brand and how much price difference?
Doesnt do that. Not really advise to. If you encrypt your card using a phone. And you take it out to use in other device. You cant. And to encrypt and decrypt takes some time. Depending on the amount of info in your card.
Depends with model
If Sandisk microsdhc & microsdxc?
I heard from my friends say that Kingston support lifetime warranty? How about Sandisk and Lexar?
Anyway so far I didnt hear Lexar before lol.
