See? You've come out with the best answer to your own question. Try it with your mobo audio first (assuming mobo supports all the audio formats that are of interest to you), if it gets loud enough then you can put off purchasing an amp or DAC stack/combo....until you get the urge to upgrade. My audio setup below, Oppo HA-1 + HD600, HFM HE4XX, EnigmAcoustics Dharma D1000...So many things HAHAHA, I'm confused. Perhaps I could get the HD600, plug into my pc, listen to it. If it's too soft then I get the amplifier? I already amazed by the HD600 from a Samsung JX.
Modmic has a wireless versionOT a little, is there any detachable wireless mic in the market? Tot of using HD6xx for gaming with detachable wireless mic
https://antlionaudio.com/products/modmic-wireless?variant=12529444126775
Sent from Samsung SM-G955F using GAGT
xlr 4 pins for headphones, and xlr 3 pins for speakers.Hi there,
Same, recently just bought HD650 pairing it with jotunheim multibit and audio engine a5+ with S8 setup.
May I know what connection u are using for your headphone ? (1/4 or xlr 4 pin?) and what connection you are using for your speaker? (RCA ? or ?)
thing to note is that I'm using AK4490 DAC MODULE with my jotunheim, which is designed to be balanced. this result in a balanced input to a balanced output.
since you are using the multibit addon instead, i'm not too sure if it's designed to be balanced. if it ain't, i don't see the value of using a balanced output, since the input isn't balanced. just my 2 cents.
what about the type of cable(Brand) you using for your headphone to jotunheim? and jotunheim to speaker?
If on budget for DAC to speaker, just head over to LHS electric at SLT lvl 2 near to escalator. They can help to DIY XLR to speaker connector. Can use canare cables or so, dun think can hear the diff.
im considering to get pure silver from diy price range at 2xx to 3xx or from aftermarket brands such as effect audio -Thor Silver 2+ / double helix (Complement 4 / Elite 19)
not sure about other headphones but my d2000 can get real bothersome to keep it on within an hour of using it in typical singapore ambient temperatureoff topic:
I have tried headphone before, but it gets uncomfortable (hot/sweaty) after a while due to our humid/hot climate.
I much prefer IEMs. Perhaps headphone is best suited for aircond environment? Would like to know your own experience.
i'm not exactly a believer in cables... i would rather spend the money on better equipment. the only criteria that i have for cables is that they must be well built, and where possible, grounded or balanced. the theory is the same as using shielded ethernet cables running over possible interference - you wanna reduce the amount of interference as much as possible.what about the type of cable(Brand) you using for your headphone to jotunheim? and jotunheim to speaker?
off topic:
yeap, i'd mentioned this in my previous reply.It’s important to note that using a balanced cable on an unbalanced signal gives you no benefits. The jacks on the gear on both ends of the cable must be designed for balanced signals as well; otherwise there’s no circuitry to do the polarity inversion that produces the noise cancellation so using balance cable alone would be pointless if you have unbalance gear along the the signal chain.
Even in aircon, after a while headphones will get uncomfortable.
Have you tried open-back headphones with velour pads? Those are super comfy and feels like your ear is resting on 2 pillow. I can wear it for 8 hours or longer without taking if off and no sweat at all. No air con also. Super comfy. When I use closed back headphones with leather earpads those will be super uncomfortable after few hours of usage will tend to sweat on the leather earpads. Went for open back headphones with velour pads and never look back. Super comfy can wear for long hours (8 or more). And with the lessen clamping force it feels like your not wearing anything at all.
Earbuds I feel its not as comfortable compare to velour headphones because the earbuds I feel quite uncomfortable after long hours of usage due to it sticking in my ear canal can feel not comfy and headache after long hours.
Headphones still my preferred choice. Earbuds more for short 1-2 hours out door usage.
Agreed, you might need serious source and gear to hear a difference (if any at all), not a believer of cables myself though I'd gotten EA Thor Silver, a couple of ALO SXC8's for my Fitear Parterre and CA Jupiter.....mostly IEM cables. Been told IEM's, due to their construction, respond positively to better cables (much to my surprise, I hear a difference between the standard Litz cable that came with my Jupiter vs ALO SXC8). For headphones, I do get after market cables, just not expensive ones, more for Balanced mode.If u already have the headphones, i would suggest to bring down and try out. Sometimes, you may not hear the difference and may wonder if it will be worth it or not. Coz cables and all are very very subjective.
