Serious help: cpu burning smoke
  • Need someone to talk to?
Rgyl11
Hi so I was using my desktop halfway when I suddenly smell sometime burning really strong and heavy smoke started coming out of my cpu area. I immediately turn off my power plug. Open up my case and check on my gpu seems fine. Smell was stronger around motherboards fan and psu but uncertain about the real issue. Hopefully any veteran can enlighten me please.
PS I'm sorry if posted in irrelevant section. Anxiety attack on me rn
Suspect is PSU.
Remove PSU and try to isolate the smell.
Rgyl11
Ok.. So I'm 90 % sure it's from psu.. Am I still able to use with low chance of getting burnt or I'll have to replace it?
jtjt00
TS, list down all parts of your rig like those on the right -->
pedokuma
your fans connection is correct? Beware that the fans may be drawing more power than the motherboard header can provide. That could kill the board some times.
most likely is psu since smoke/burn damage are easily visible by eyes if you can't find any visible damage on the board/cpu/fans.
burn damage looks like this
What psu you using? Lower quality PSU uses weaker cap that might caused the burn if your board is okay.
Steyr69
Hi TS, define what you mean by CPU area? For PC ppl, CPU is the processor mounted on the motherboard. If smoke comes out that area.....then should see blacken marks on the motherboard.
Sent from Asus ME173X using GAGT
Rgyl11
Acer m7720
Processor
I7 920
Mainboard
Acer no idea
Graphics Card
Asus 750 ti
Memory
6gb
Display
Acer p235?
Storage
Toshiba 1TB iirc, acer Oem crashed
Casing
Acer m7720
PSU
Cs750m corsair
Audio
Sorry for being noob
Thanks
Rgyl11
No burnt mark yet as I immediately off power plug. No idea where it's coming from
bunnypangsai
Wa. This kind can rma the board or not?
Rgyl11
As in I saw it coming from back of the case then I immediately off the power plug. Let it cool down for awhile before opening and smoke had been spread out
Mobo smelt burn too tho am still confuse
pedokuma
Have smoke = burn and able to see burn markings / exploded caps if on board.
any overvoltage to the fans might cause burn too.
