Serious help: cpu burning smoke
  • Need someone to talk to?
pedokuma
Yeah 1 month old. Still under warranty from some shop in sim lim . Kinda regret changing it tho cause shop assistant told me power not enough for asus 750 ti for my original 460 acer psu
750 TI need 750W? That is pretty overkill. haha. You fixed the psu yourself or the shop helped? Some case fans cannot tahan overvoltage one since your computer is from Acer, and will burn the board/psu with the fans.
pedokuma
Still under warranty can 1 to 1 hor?
bring to distro, they will do testing for you. If it is indeed spoilt, they should replace it.
IIRC, 7 years warranty for that psu. but try to see the front and back of the board , cpu , all parts to locate any burn first.
Rgyl11
Shop help. With fee of course. Why didn't he mention this to me damn it. He told me for future upgrades it's useful. That's all.
Rgyl11
Think 3 years only. So I bring back to the sim lim shop right?
sacredrays
did you told him you using 750ti? 750w very very overkill, shop recommend it or you ownself choose? :eek::eek::eek:
Koenig168
Wattage has nothing to do with voltage.
sacredrays
Most likely kenna psycho.....and i have reason to believe such an unethical shop could have install a known defective unit into TS pc. So im asking TS to name the shop.
Sent from Asus ME173X using GAGT
same thinking lor. i would black list it too. but of course need confirmation by ts first. seems like he don't know what's going on when he buy it.
Rgyl11
He fix my gpu for me too. He did recommend 660 cm but told me is old model the corsair is newer and make me tempted as he say next time diy can reuse
sacredrays
even if use corsair... got lower wattage one mah.. he specifically recommend the 750watt?
Steyr69
It is ok....there is always a first time. At least he is smart enough now to approach HWC !!
20 years ago, I paid a pc expert 300+ to change my mobo cause he say my mobo spoilt....i dun even know how the inside of my white pc casing looks like....thinking back....he might not had changed the mobo!!!
Koenig168
it was 2 separate questions i think. cause you see he list his spec you also will :eek::eek: at the psu.
I saw. While the PSU is more powerful than he needs, it will only affect efficiency. My point is that a PSU with higher wattage does not mean that it will supply more volts. The fans are likely powered off the 12V rail, which will still be 12V whether you use a 300W PSU or 1000W PSU.
pedokuma
Apparently he only sell limited product as he is more on repairing computers
since he is into repairing pc, maybe bring to let them check lor. Most likely they will ignore you unless you pay a fees. Most shops after assembling the pc for you, after 1-2 weeks, is not their taichi liao.
else, corsair RMA center is
CONVERGENT SYSTEMS (S) PTE. LTD.
9 Ubi Crescent
Singapore 408572
Tel: +65 6337-0177
Opening Hours -
Weekdays: 9am-6:30pm (Service Department: 9:30am - 6:15pm).
Closed on Saturdays, Sundays & Public Holidays.
