SET ST536v6 to bridge mode
Diavonex
Looks like your ST536v6 is still in ADSL Gateway mode if you are using the LAN port of router.
Your router is basically acting as a switch.
Diavonex
To check if ST536v6 is in bridge mode:
1. After setting to bridge mode, connect ST536v6 directly to the computer.
2. Use Windows to create a dialer and check if you can connect to internet.
Diavonex
How to create dialer:
Control Panel>Network Connections>Create a new connection>Welcome to the New Connection Wizard>Connect to the Internet>Setup my connection manually>Connecting using a broadband connection that requires a user name and password>ISP name>Enter user name and password>Add a shortcut to this connection to my desktop.
Diavonex
Create New Connection
bwaysaigong
Hi Diavonex,
1) Yes, I am currently using Linksys as a switch :(
2) Yes, I used the Residential CD on the first page to change to bridge mode.
3) I will try and post my result using the windows dialer.
Thanks for helping :)
kHyber_pass
good, lean way to configure ST536 to bridge mode WITHOUT Residential CD!
perfect for the hardwarezone techie.
ynzai said:
Ok...after few days of calling SNBB helpdesk .... finally got the solution to revert my ST536v6 modem back to bridge mode. You will need to call up Thos Solution Tel:67739693
Anyway, I post it here :-
To set the modem to a bridged mode, please ensure that your PC is connected directly to the SpeedTouch.
If you have previously set up the modem to connect to the internet, you will need to disconnect it using a web browser.
Go to http://192.168.1.254 and Under Broadband connection, click on
'Disconnect' button.
You can then close the browser. (The Internet LED should be off)
To perform a telnet to the modem, click on (Start, select "Run..." and type in: cmd[Enter]
(for Windows 98se or Windows Millennium, type: command [Enter] )
if the command is successful, you should see a black color DOS screen.
Type in the following
telnet 192.168.1.254[Enter]
When prompted for authentication, please provide the following information.
username: Administrator[Enter]
password: [Enter]
You should then see a prompt like the one below:
{Administrator}=>
Please type in the commands as they appear after the ">" symbol.
_{Administrator}=>ppp relay
{Administrator}[ppp relay]=>flush
{Administrator}[ppp relay]=>..
{Administrator}[ppp]=>flush
{Administrator}[ppp]=>:eth
{Administrator}[eth]=>flush
{Administrator}[eth]=>:atm
{Administrator}[atm]=>flush
{Administrator}[atm]=>phonebook
{Administrator}[atm phonebook]=>flush
{Administrator}[atm phonebook]=>add
name = pvcInternet
addr = 0.100
:atm phonebook add name=pvcInternet addr=0*100
{Administrator}[atm phonebook]=>..
{Administrator}[atm]=>ifadd
intf = atmInternet
:atm ifadd intf=atmInternet
{Administrator}[atm]=>ifconfig
intf = atmInternet
[dest] = pvcInternet
[qos] = default
[encaps] = llc
[retry] = 10
[fcs] = disabled
[ulp] = mac
:atm ifconfig intf=atmInternet dest=pvcInternet ulp=mac
{Administrator}[atm]=>ifattach
intf = atmInternet
:atm ifattach intf=atmInternet
{Administrator}[atm]=>..
{Administrator}=>eth bridge
{Administrator}[eth bridge]=>ifadd
intf = snbbridge
:eth bridge ifadd intf=snbbridge
{Administrator}[eth bridge]=>ifconfig
intf = snbbridge
[dest] = atmInternet
[portstate] = forwarding
[retry] = 10
[vlan] = default
[prioconfig] = disabled
[ipprec] = disabled
[priority] = 0
[regenprio] = 01234567
[ingressfiltering] = disabled
[acceptvlanonly] = disabled
[mcastfilter] = disabled
[dynvlan] = disabled
[igmpsnooping] = enabled
:eth bridge ifconfig intf=snbbridge dest=atmInternet
{Administrator}[eth bridge]=>ifattach
intf = snbbridge
:eth bridge ifattach intf=snbbridge
{Administrator}[eth bridge]=>saveall
{Administrator}[eth bridge]=>:
{Administrator}=>dhcp server config state=disabled
{Administrator}=>saveall
Administrator}=>exit
Connection to host lost.
tungsten2
bwaysaigong said:
Hi, I have a problem here :(
My setup
ST536v6 (6.1.0.5) ethernet --> (wan) Linksys WRT54G v7 (lan) --> (ethernet) PC
I have set up my ST536v6 into bridge mode according to Diavonex settings. (basic --> bridge)
Then I setup in my Linksys setup page my PPPoE username and password.
Then I went to the Linksys status page and found it is disconnected. I click on the CONNECT button.
After a while, it is connected and I get a public IP in the range of 220.xxx.xxx.xxx
When I am using my PC to go online, after about 20s, I get disconnected.
I went back to the Linksys status page and it gives an error "PPPoE LCP negotiation failed".
All the IP address become 0.0.0.0
I click on CONNECT button again, and I get Public IP again, then same symptom happens.
The 3rd time I do it, it tell me "Cannot get an IP from PPPoE server"
I don't know why is it like that when nobody else is facing this problem :(
Hi bwaysaigong,
I'm also facing the "PPPoE LCP negotiation failed" Errors
I have to wait for 5 mins in order for the ST536v6 modem to communicate with the Linksys modem b4 can surf the net.
maxpower
I tried using the residential CD, after the last step..configuring the computer it stops at 75% waited for 10mins, I click cancel and I cant use the web interface to access the modem anymore, does this means I have successfully enabled its bridge mode? Also after restart, my wireless services was disabled....is this singnet's way to discourage u from using wireless access if u got the wired modem?!?!?!?
tungsten2
By manually configuring a dialer, you can test if you have successfully bridge your modem.
Alternatively proceed to configure your wireless router to PPoE to test it also can do.
Porkbone
anyone got problem when setting up bridge mode using the ISO downloaded from the first page?
everytime where i reach the page which says region , provider , service
mine is all grey out
can't choose and proceed
tungsten2
The ISO definitely NO PROBLEM.
Cos I have tried it out on at least 2 homes, downloaded twice and burned twice, and twice working fine.
As to greying out, I don't understand why either.
Diavonex
Did you download this:
AttentioN
Hi all.
Ive just received my ST536v6 today. Line has been activated. From the box, one of the line in the specs says Self learning Bridge and it works i guess.
Just now i connected the modem to my router after doing some basic config (username and password). Few minutes later, im connected to the internet. No need to do bridging like what have been discussed in this thread.
But now, im doing direct connection just to make sure the router isnt the cause of any initial problem i might encounter. :)
liangtam
Yar, the modem does actually accept incomin PPPoE connection even in gateway mode with no username and password keyed. Don't understand why so many ppl keep getting the residential disc without trying much.
AttentioN
Yea. For this one, i tried the residential thingie also. it asked for username and password. I input Administrator for username and nothing for password. But authentication failed. weird.
Anyway, i intend to use DIR655 with this ST536v6. Will ST536v6 hinder the performance of my DIR655?
benphoon
yah i cant get around the username and password part too... perhaps singnet changed it to something else?
one question... i went to the modem configuration page and saw this:
Service Name: Routed PPPoE on 0/100 Bridge 1/100 (modified by user)
does that mean my modem is already in bridge mode? unfortunately i still cant get my wtr54g to work with the modem =(
benphoon
alrite which means i still have to go thru the manual bridging process... but i still cant get past the username and password, anybody?
