Should I buy cheaper inkjet or laser multi function printer?
Nakedtoes
injet if u print colors and print very often... espon got 1 the ink quite cheap.. else choose laser
Nakedtoes
I used to do that. Then switch to ink tank. Working for 3 years
Those who say ink gets clogged probably because using non-refillable printers. Specialised ones use different print head
the ink tank looks ulgy will spill off or not
commach
Now my laser printer not much paper jam, suspecting I putting in too much paper inside the tray. As it can hold up to 250 sheets of paper in the tray, I put over 200, should put 100 plus paper since I do less printing. I trying to monitor for a few weeks to hold on to buying new first.
Did you fan the paper before you put them into the paper tray?
I noticed many users totally ignorant about fanning the paper, end up paper jam when multiple sheet fed into the printer.
xiaowhois
i used cheap canon laser AIO and buy the toner from taobao cheap cheap even with shipping as i dont print color
koreanlover
Need to check how much the ink refills costs.
If third party should be cheaper.
bunnypangsai
laser laser lumber huan. Now so cheap. cheap printer plus cheap toner. everything cheap cheap.
wacko
inkjets have the ability to give you photolab-quality prints, which laser printers are not capable of. each has its pros and cons.
Ohayo!
i think also depends on what paper u use
some too thick then jam
commach
SOHO printer rarely jam because of thicker paper, typical 80grams. It jammed frequently on thinner 70grams paper instead.
