Sim only plan with 5Gfor iPhone 13pro max
vuzuuu
Hi, which service providers in sg provides wide 5G network coverage? I am thinking to switch from my singtel combo plan to SIM CARD ONLY plan with 5G for my new iPhone 13PM.
I’m currently using 12PM and my combo plan doesn’t come with 5G network.
Thanks.
ragnarok95
Senior Moderator
Senior Moderator
Starhub 5G sim only plan. But it comes with 1yr contract.
mikeeeey
Thanks.
I got the $25 for 80GB plan.
add $15 for 5G network and additional 10GB
tohchr
Esim only singtel have it.
Singtel esim only for watches. For apple watch, that's not really an esim but it's the same mobile number using number share method. Watches like Samsung and Huawei, it's using esim which u need to scan the barcode to activate it.
fxsg123
What plan is this? Which provider?
I think is Singtel SIM Only. (Do take note its for new sign-up only) 1 yr contract.
For short term, this kind need to consider before jump in cause you are lock-in.
For long term, after 1 yr need to jump/change else all the cost start to kick-in
mikeeeey
Only thing that will change is the data will be 60GB after 3 months.
Still a lot for my use
Groudon
I've been investigating this and here are the current options:
- StarHub $38 5G SIM-only (1-yr contract)
- Circles 5G Add-on ($7) (on M1 Network)
- M1 (old) - $5 add-on
- M1 Bespoke - $15 add-on
- Singtel SIM-only with $15 5G add-on (1-yr contract)
Currently on Circles, and it's 5G NSA only, and the coverage really isn't wide (https://circlesasiasupport.zendesk....ingapore-where-Circles-Life-s-5G-is-available), so preferably I would avoid for now.
M1 and Singtel should be providing the new 5G SA SIM card. For Singtel, I believe there have been posts here that state the iPhone 12 has been able to connect to SA network despite it not being officially supported (?) so hopefully it'll be same for the 13. Not sure about SA for M1 on the iPhone even though it does have support for the band (but not sure if the carrier profile for the SA network is present).
Kiddream
Giga also just launched their 5G pack. Free for the first month and subsequently $10 each month.
