- Sep 16, 2018
Service finally back online. ~34hrs downtime.
Falling back on tethered 4G even if you have 100gb of data is really sucking the internet thru a straw.
This is probably the reason why I would not recommend to use SIMBA as the only ISP. Stability is more important than speed.
Then the support seems to be not good either.
Connection problem to SingTel (maybe Starhub and other places as well) is another issue.
But SIMBA can be a good ISP plan to go, if you want to have two ISPs.
