SIMBA Fibre Broadband
joesph
what's the model number for the huawei router with the 6GHz band? plan to buy people sell away set
https://www.hardwarezone.com.sg/tech-show/view-brochure/9764099?ref=brochureleft
6bc32493493a2f7d434a3d3c2ba7958798333647069a12c31bd5426c14b0ca24
xp20046
I have log a ticket with them and this is what i got, i request them to change back to the IP range i had previously but they just brush it off. Seems like the sites that got redirected/block need to whitelist this range.
Thank you for contacting SIMBA Customer Support!
We have confirmed that the affected IP address range is assigned to SIMBA and is registered as being in Singapore.
If a particular service, such as your work VPN, gaming or streaming platform, is showing an incorrect location, this may be due to the service’s own IP location records. In this case, we recommend reaching out to the respective service provider so they can review and update their records accordingly.
I asked the question about the Huawei mesh solution model info and the following is the reply.
ONR: Huawei OptiXstar HX8145B7s-6x
10G MESH ROUTER: Huawei OptiXstar LN8145B7-6X
2.5G MESH ROUTER: Huawei OptiXstar K572
More information
Answer from SIMBA Fibre Broadband thread.
https://www.csa.gov.sg/our-programm...lling-scheme/cls-items/?search=Huawei+&page=1
1) Huawei 10G Wi-Fi 7 ONR, BE9700
Model No.: HX8145B7s-6X
CLS Level: Level 2
Registration ID: CSA/IOTZ0029
Date of Issuance: 27 August 2026
Date of Expiration: 26 August 2029
Issued via Mutual Recognition: -
Assessed By: SGS Brightsight
2) Huawei 10G Mesh Router, BE9700
Model No.: LN8145B7-6X
CLS Level: Level 2
Registration ID: CSA/IOTZ0030
3) Huawei 2.5G Mesh Router, BE3600
Model No.: K572
CLS Level: Level 2
Registration ID: CSA/IOTZ0028
Comments about Huawei mesh solution versus Amazon eero mesh solution.
SIMBA is providing 10G Wi-Fi 7 ONR plus two 2.5Gbe mesh nodes fir the 10Gbps plan at S$29.99 per 30 days.
https://simba.sg/broadband
This can be a cost effective solution compared to the other SIMBA 10Gbps option at the same price but with eero Pro 7 10Gbps router.
Huawei will be the sole source of any/all firmware updates for these products. Huawei has locked out community firmware projects such as OpenWrt. Among other problems, their boot loaders don’t allow any other firmware. (Some vendors, such as MikroTik, explicitly cater to independent firmware projects in their boot loaders.) In short, you’ve got to trust Huawei to supply timely firmware updates to keep your network gear secure, and for at least the span of time you want to run these devices.
Per the CLS, Huawei is promising updates for the FG736 only through September 17, 2028. The SIMBA-supplied Huawei equipment is through August 26, 2029.
If you’re considering network devices that don’t have independent community firmware options, Amazon is currently promising security updates for all eero 6 and 7 series products (except the eero Pro 6) through at least September 30, 2031. (The eero Pro 6 ends on July 13, 2030.) But that date will surely shift out since the actual promise is for at least 5 years from last new retail sale from Amazon. The TP-Link Archer BE450 is among the many OpenWrt compatible wireless routers if you want something with an independent firmware option — and OpenWrt updates probably for a decade or more to come.
eversomighty
Hi, any idea if out of contract existing SIMBA broadband customers can get the launch promo 29.99/m with FREE WiFi 7 (10G) ONR (worth $699) and FREE 2 X Huawei OptiXstar WiFi 7 (2.5Gb router (worth $598)? Do I just sign up online as per usual or have to go to shop to sign contract? Thank you
can recontract and get it but their system is down for the last week... :rolleyes:
Fragum
Modem shows red blinking light at LOS since Monday, called customer support. They are sending someone down today.
Contract only started in April this year… haiz
HiHelloBye
LOS = Loss of Signal
reasons why:
1. Faulty Fibre Patch Cord
2. No Light Source to your FTP (i.e. Fibre Cut)
3. High Loss Reading to your FTP
kineticworks007
I am currently on Simba 10G plan, and I am planning to upgrade my home network to support 10G setup. Wonder if there is any kind soul to guide me to the right direction for gear acquisition.
Found a good offer for EB810v(SH) and HB810(ST), thought of pairing it with my existing ONT, but I read from another thread that it is not compatible because of ISP FW lock issue? I am quite sure someone has tried to run this combi before? What are the Pros and Cons?
The extra 2.5G and 10G ports are really handy. My goal is to achieve a 2 pack mesh network for HDB size home setup with improved coverage and speed at < $300/pack. Do recommend if you have better tested setup in mind for me.
Thanks for the help in advance. Haha, I have to admit that I am quite lost touch with modern WIFI network.
