Encrypted11
- Jun 9, 2012
Bf3 is playable on ultra? Hmm..might consider joining team red then..
Actually, med to be smoother.
And the performance will match Intel Pentium G2130 + HD7770?
Without GPU
You can play BF3 on ultra with an APU if you don't mind watching a slideshow
What's your monitor resolution?
Well, if you're getting anything 22" or above it should be 1080p. Below that it should be 1680x1050 or the 16:9 equivalent.
If you're looking to get a properly decent monitor the Dell 2312HM is selling for $255.
Intel Core i5 3330 + Asrock B75 Pro3 M - $346
Kingston 1600MHz CL11 Value RAM 4GB - $47
Plextor M5S 128GB SATA-3 SSD - $139
WD Caviar Blue 1TB SATA-3 HDD - $85
Powercolor HD7850 2GB - $251
Seasonic S12II 520W PSU - $89
Windows 7 Home Premium - $120
Some random branded USB3.0 ATX case - $59
The only changes are the CPU and graphics card. This will sail through any 25-man raid in Pandaria at max settings + max AA at 1080p (and most other games too). WoW's been upping the graphics requirements significantly every expansion, so this should be adequate in case that happens again. Basically this setup will give you years of high-settings gaming.
The Haswell upgrade (i5 4430) will require $23 top-up. I don't see the need for it TBH.
Ripped right off the list I made in the first page. The "take out anything unneeded" statement still applies.
An SSD + HDD combo allows you both the fast startup and reading speeds of the SSD and the storage space of the HDD. SSDs aren't as durable as HDDs if used for a lot of data writing so the HDD also helps relieve that load.
If you don't need fast startup/load times, just ditch the SSD; if you don't need the space, take out the HDD.
Means what ah..
Will it affect the user/gaming experience at all?
Actually right now I only play WoW.
Can have decent frame rate at max graphic settings in 25m raids I happy liao
What I initially posted was their recommended specs, so I was thinking I'll just get the cheapest thing that's equal or better performance
Don't really quite understand what you are talking. Do you actually have a budget range rather than jus stating you want the cheapest?
