SimplyGo with Visa
WoShiPro
Had my 1st missing entry.. using since launch.
Simplygo app notification show correct amount deducted but next day become missing entry.
cassowary18
What's the best current promo for SimplyGo? Cashback, not miles. Preferably no minimum spend. Can be visa or mastercard
koreanlover
I submitted a claim and it was approved.
Will the amount be automatically refunded to my card or do I need to do something?
WoShiPro
Submitted 2 claims but 1 was rejected. Combined trip is only $1.55 but because of missing entry it's spilt into 2 trip 1.28(claim approved) + 0.83(2nd trip claim rejected)
It is usually this case where the 2nd trip can't be claim?
hyperbole
they will usually reject 1 claim but total amount refunded should be correct
dash_slate
Recently I experienced a lot of missing entry/exit. I used the same card / phone tap as before. It is getting really irritating to claim. Anyone experienced similar issue?
hyperbole
Did you wait for the charges to be confirmed before claiming?
koreanlover
I discovered the charges for Tues in SimplyGo did not tally with my card txn history.
SimplyGo showed $3+, but I was charged $5+.
SimplyGo did not show any error (missing entry, exit or surcharge).
Txn is charged but not posted yet. :(
Looks like got to claim again lol.
vsvs24
Check again after a few days. SimplyGo will likely adjust to $5 later.
juxtaposition
Saw it in my updated iOS
MrRainbow
Anyone use dash to commute? Mrt/bus?
Added my dash visa to TLsimplygo to check my transactions, but they are not appearing?
silverbomb
u need to add the dash transit card number, which is another set of VISA card number different from the normal VISA card u see on the main screen. under commute button.
