Singtel Sim Card Problem
CrispyPeddler
As above, i lost my sim card and requested new sim card from singtel.
received the new sim card and activated. now it can send out msg and do phonecall only.
for watever reasons, it cant receive sms, cant receive call and no data.
have call helpline and even went to singtel customer service counter. they troubleshoot and even change new sim card and try it on other phones...it still the same.
bros here any advice or face similar problem before? any solution?
helppp:(
renfred89
helppp:(
what if you put the sim card into another phone, does it work?
CrispyPeddler
tested on several phone. same issue..apparently singtel itself dont know whats the problem.
they change sim card..try other phones....so the only possibility shud be the number itself right?
keenklee
dont have. just one only....:(
I asked because it is somewhat behaving like a multi-sim non primary card i.e. can make call and send SMS but cannot receive call and receive SMS.
The only difference from your scenario is the non primary card can have data. The data could be some setting issue though.
Anyway, you may want to try to set the sim card to primary - Dial *141# and press send.
CrispyPeddler
i press that..and it says "to subscribe to singtel's multi-sim service, please visit a singtel retail shop"
CrispyPeddler
same as in? i reported lost..they suspend the previous 1..i get the new 1 which the number still the same
keenklee
That is what I meant by same number.
I think very likely they need to do something at their end.
I am on multi-sim with same number for both sim.
I vaguely recall something like if I lose one of my SIM, it is more troublesome.
renfred89
try calling 1688 technical support, mobile section. they should be able to help you by doing a line reset.
since you are not on mobile share, the matter simplifies alot already. My guess is that some configuration might have gone wrong when they registered your new sim card to your account considering you have suspended your account..
CrispyPeddler
i did called 1688 and they resetted the line twice. and now it still the same.
i argued with them telling them its their end that have the problem and asking them really check their system and do a clean reset..they even suggest if all fails..backup and reset my phone:s22:
haish..jin suay..
kero89
haish..jin suay..
Hmm I was wondering the messages and call u made from this sim card, is still your number right? :o
ZrE0_Cha0s
haish..jin suay..
go down to singtelshop and ask their stuff over there to check for u the issues,
renfred89
haish..jin suay..
you might wanna try resetting network settings on your phone? android and iOS will have this option.
If all things fail, maybe need to change sim card again..
CrispyPeddler
hi all, thanks for the advice. its solved already. i think what it needed is just time =).
thanks allll! :D
Tornesoul
helppp:(
Bro how u request the sim card? Call 1688 or go shop?
Free?
Sent from Sent from where? using GAGT
