Small Rice Chat
RyanJ
SantyBalls
isn't there an app notifications?
I'm still using old control center style
I tried searching "control center" in settings, nothing.
Im using poco x7 pro in hyperos 2.
V strange lor. I don't like need to top left and top right swipe down.
I just want to swipe down see all my system toggles and notifications like my old miui
rrr2015
looks like not available for poco x7 pro
maybe time to make some noise in MIUI community?
PES1989
All my Redmi, Poco & XM hp on older MIUI firmware can still do that, only my XM tablet on older MIUI separate to top left & right.
Lasogette
sharing my mi 9t repair here..
i replaced the white tape thing. to replace with my own 2mm double sided tape. turns out, my tape is too thin. stack 5layers also cant paste it tgt.
end up, i ownself cut my own tape from this tape i last time bought from shopee:
double-sided-tape-nano-tape-removable-reusable-waterproof-adhesive-tape-multi-purpose-traceless-adhesive-ucfe_600.JPG
i v stupid la, while trying to cut small strips, i at first limit the length my of penknife. then i instinctively keep making blade longer. by the time im done, i realised i accidentally slashed my silicon repair matt many times :(
now my mi 9t pro is held tgt with double sided tape. no glue.
screen held tgt by 2mm thin tape.
back glass held tgt by DIY silicon flexible tape
turn on phone, go settings, about phone, kernel, tap it like 5 times to open up CIT, do all the diagnostic testing there.
new issue: vibration not working. i open it up again, and start it, and somehow it works. motor spins. but once i assemble it, turn on again, it doesnt work. idk why. maybe its the loudspeaker assemble got something preventing it from spinning..
too much work to figure it out.
for those interested, there are stencils where the tape is precut for you. something like this. its basically rubber/silicon double sided tape that is pre-cut. if your phone have like protruding stuff like a camera, they will cut out the stencil of the camera so u can position it nicely, remove the plastic, and apply the tape onto your phone, and can achieve pretty good waterproofing.
these are like 2dollar ea.
i believe many hp repair shops use this for iphone and samsungs cause it's common models and it saves alot labour. prolly <50cent ea if bought in bulk. i spent like 1hr cutting my own tape lol
S955aae3c4ade4b49a56246ec176c7f50g.jpg_960x960q75.jpg_.avif
Wah power sia. Normally when u fix the old phones u just use it with the old roms ?
I got one is the button cannot on. When I free I will try embark on this fix it journey. Looks very interesting.
SantyBalls
If too old os then i flash rom. Like my note 4 now running android 11 or something.
Power button some time is just contact. Normally if u slip in a small pc of plastic then ok liao. I fixed this phone power button liddat also. Same for huawei.
Lasogette
Wah nice bro. I tried opening it up and realized the battery was cui liao. Cannot charge. So will need to fix both button and battery.
U got try before installing windows 11 for Arm? I saw some YouTube video like very interesting. Lol
SantyBalls
I against windows. U need to see if it supports ur processor first.
I just flash custom rom(lineageos) on it so it can run the latest apps very slowly.
SantyBalls
Your blue mat buy from where ar. Like very pro.
Ezbuy clearance. Was free with voucher.
Can search silicone repair mat or silicone soldering mat.
Small 1 afew bucks nia
Tbh, don't need these stuff 1. Its useful if u soldering or using hot gun. Its just an environment to hold everything nicely.
Any nonslip surface can liao.
Lasogette
Thanks man.
Lasogette
Btw where do u buy those spare battery and is it official Xiaomi OEM one ?
SantyBalls
All parts either shopee or last time ezbuy.
If phone too old, just pm any seller ask if have. Most of em are dropshipper, can call factory ask.
Battery replacement need more careful. Always drain the battery first b4 attempting to pry it out. Never pry out a fully charged battery. Use alcohol soften the adhesive first.
