Sony 1000xm3
ichinisan
Same chip so likely same performance. Minor exterior updates, e.g. thicker pads, reworked hinges, etc. New features will be the pause on remove, possibly multi-point, etc. Not much improvement if you alr own a XM3 unless those new features are a must have for you.
Quite disappointing to know that there is not much of an upgrade for the XM4.
superio
Hi all,
Xm3 Earbuds vs headphones
Which would you choose and why?
Also, if my desktop doesn't have Bluetooth, can i buy a USB Bluetooth adaptor so I can listen to music and do video conferencing on my desktop? Will there be any lag or other issues? Bluetooth 4.0 adaptor?
Thanks!
qwertified
Hi all,
Thanks!
I suggest you stick to using wired earphones with mic for desktop video conferencing. Bluetooth headphones arent good for that when connected to pc because they wont switch functions automatically for you. You need to know to enable/disable devices manually to get it to work for you. For entertainment purposes, sure. The delay is there but you wont notice it most of the time. Personally i only really notice bluetooth lag when i play music/rhythm games like djmax or cytus.
edify123
I saw Lazada selling xm3 without Google assistant for cheaper. Is Google assistant really necessary? If not should I go for the cheaper one?
superio
Thank you bro. Appreciate it. 🙏
miketanct
I saw on Lazada XM4 promo at $469 this morning. :s12: But when I clicked add to cart, it changed to $499. :(
Now still $499.
Think I will wait for 11.11 promo or black Friday liao.
Still happy with my XM3 atm, esp after having just changed to new earpads recently. :)
MrMundy
I changed to dekoni suede pads on my xm3 recently and the ANC is not as good as before, but very comfortable:s13::s13:
The multi device feature on the xm4 looks very tempting..
Converged
Where to buy cheap xm3
Posted from PCWX using 6666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666666
qyc_91
pretty good deal but I think Challenger also have discount at $389 now..
if you guys don't required multipoint then it's a really really good deal to go for it under $350
stormycloud
Saw on carousell people are selling bnib for 290 for xm3. Is it worth hooting the xm4 over 3? Like do they still update the xm3 ? The price difference is huge and i love my wf 1000xm3 earbuds so i dont mind trying out the wh series
qyc_91
WH is alr sound better than WF due to its over the ear design.. XM4 is said to further improve on XM3 but I think most people would be satisfied enough to XM3 quality..
stormycloud
Maybe i find it too much paying 500 dollars for a headphones. So might consider the xm3 at 300 dollar price point more affordable
qyc_91
To each his own
If you think it’ll be great for you just go ahead.. it’s a long term investment after all unlike wireless earbud where the battery probably starts to die within 2 years..
Is it too over kill to buy xm4 to listen to Spotify?
