Sony Android TV
ahbao
Hi. Any experts can kindly help to advise how to install free movies onto android TVs?
Courts can help customers install all the free apk files for movies if u buy TV from them. But I already got one from other place, and dun know to do it myself. Really appreciate if some kind sifu can guide me.
Please help! Thanks!
enable install from unknown source in the setting
install a file manager from the play store
copy the apk into the thumb drive and connect to tv
use the file manager to install
after installed, if the app is not showing up in the app list, use this app to generate a shortcut icon
https://www.apkmirror.com/apk/felke...roid-tv-1-1-4-playstore-android-apk-download/
ehsevol
Hi all... just got Sony 50W660F. It's not android tv, only a smart tv. Any idea how I can mirror/cast my iPhone screen wirelessly? Been googling but seems like only can do it on an android tv :(
dot123
Hi. New to this thread. Anyone got any pricing for x8300f?
Looking for both the 60” and 70” screens. Any good sony salesman to recommend? Thanks!
clowong
I got my Sony from Tampines Courts megamall. The Sony salesman is good and very informative.
BlackStorm
watch tamil movies.. downlaod or any other ways... brand? model ?
Any INDians watch TAMIL movies in NETFLIX please msg me...what model ? brands supports for tamilmovies...sony ? LG ? samsung ? etc :s12::s11::s11:
kianzzz
Can I check please?
I saw a display set X85 75 inch at $3700. but there was a dead pixel. The salesperson told me he can get sony to replace the panel & I can go down check before committing. Anyone knows if it's worth the risk to buy it after the panel has been replaced?
Posted from PCWX using LYA-L29
xiangzeng
Can I check please?
Go and find another shop that sells completely perfect tv screen is the safest way to buy a new tv. No one is certain sony repair centre will change it for you.
Columbian78
I have the X9000F 55inch.
I realise the ethernet seems to be only 100mbps. is this true?
It is connected directly to my router LAN port using cat6 and my fiber is 500. I have tested by connecting the same cable end to my PC and it indicated 1gbps on my router and gets >>100mbps.
The specs say the wifi has AC standard. So again i try to connect using wifi, again it gives < 100mbps. using my other devices I can get >>100. the router is next to the TV.
Buckbrick
Going to replace my 50” Sony. Anyone have a 65”, sitting distance of 2.8m? Will it be too big?
sHaDy69
Hi, having a strange issue with my Z9D there is some artifacts on the top of the screen
p6mtF2h
Anyone had the same issue before?
LouisSaha
Anyone notice? Nowadays led tv, easy to spoil after like 3-4 years of usage.
Sony brands like going down.
Bought 3 sets in a timespan of 3-4 years.
Audiology93
My 1st "smart" TV was from Sony. Model is 46EX650 and paid around 2.6k for it back in 2012 from COURTS. The TV was repaired a few months right b4 the end of warranty and has been working ever since for 7 years. My Philips TV on the other hand is facing random shutdown after a certain period of time which was purchased back in 2014 on LAZADA. I think sony TV is still the longest lasting one :s13:
Sent from HUAWEI Mate 20 using GAGT
Ed.YEO
電視可以撐得幾耐,最基本嘅就係你拎架機番屋企之後有無做基本調整,嚟對應,襯你視覺環境。。。
我13年買入一部飛利浦24寸非數碼電視,直到上年轉手俾我阿叔,直到宜家架機都無問題。只有遙控某些功能失靈,完全反應唔到。
亦可以睇呀!!!
雖然話,某些電子部件會出問題,咁嘅問題唔限於某個品牌。就如樓上師兄嘅電視,2012入手,直到保固期失效之前某個部件才出事。。。之後再頂7年。。。已經算係唔錯嘍!
