Sony Android TV
yooooz
May i know whats the price and where? TQ.
Got at 2399 IT show price with HN.
I think now the price you can try nego to 2499. The 100 difference was because of the voucher offset just for the IT show which i had as I committed to the buy the tv then, just deciding which model. This was what the sales person told me. Nice guy let me take my time to compare the 2 tvs side by side somemore.
noinimod
X7500F vs X9000F = price difference of $900
If i just watch mostly korean drama (from viu) and Mio Stadium soccer, is the 900 more worth to pay? Thanks.
If the F series is anything like the E series
I spent close to an hour comparing the 7500E and 9000E side by side in a store. Same video content. There is something going on with the motion processing with the 7500E that is not as good as 9000E. It's more jittery and not as smooth.
Second difference is the 7500 doesn't go as bright as 9000. This was obvious.
Third is the lack of FALD on the 7500.. The contrast doesn't look as good.
My 2 cents may not be helpful since the models are different.. take of it what you will. :o
benzene
my sony 49inch X7500F just arrived yesterday, purchased it during IT show.
Now still trying to explore all the functions.
keywin
anybody updated the android update on your tv recently and noticed any bugs? asking before I update...
kwoh61
What is the free gift you got from the show.
I bought a 75X9000F during that time also but from HN outlet was given free antenna, hdmi cable and wireless kb & mouse. I want to know how is the quality of the wireless set, as I can exchange for those small keypad with mouse pad all in one set. I have not collect the free gift yet.
kwoh61
X9000F
Guys with the X9000F model can you try this.
For example in Netflix where the show has is a black bar at the top and bottom and when you press the display information button, the Netflix show info will appear in the top left corner with bright text but at the same time I notice the surrounding black area it have some greyish patches or image noise which stretches horizontally to about the middle of the screen. But once I switch the info off it is back to the black again. Wonder is it normal due to the bright text display.
Very nice tv and it is alright for a 75" with viewing distant of 2.7m, bonus is it can support Dolby Vision and Dolby Atmos with the built in Netflix app. The only thing I don't like is the remote control, need to point at the tv sensor location for it to work and it is block by the HT center speaker, also very confusing for me with the button so close to each other and still trying to get use to. I feel my old LG remote works much better in this respect.
derrickgoh
That’s odd my 55” 9000XF can point any where reasonably near the tv, no need specifically the sensor. Maybe your’s is faulty?
Buckbrick
Anyone has recommendations for X9000F games settings for Xbox One, especially motion? I find it more blurry when I look around quickly in FPS games, compared to my older Sony TV. Read that it’s due to the higher refresh rate (if I read it correctly). So I turned the XMotion off as custom is really blurry.
86technie
https://support.xbox.com/en-US/xbox-one/console/improve-video-quality
Buckbrick
I just pointed the remote at my face & it worked. Pointed at the ceiling also ok.
Either i got a super powerful remote or all your remotes koyak 😂
Dunno leh. If it’s not the remote then prolly it’s a lag in the software something.
mrsun18
Weak batteries? And I think the remote has both IR and bluetooth connectivity. So a working one can work even without point it directly at the TV IR sensor.
Fellowes
So those using X9000F what's the latest Android version? 8.1 Oreo or upgraded to latest 9.0 Pie?
86technie
The new Android doubt will come so soon, X9000F isn't the only model
that there will be new Android version.
