Sony Android TV
HMAN
Need to get some feedback from Sony Android TV users here. Eversince the Firmware ugprade to Android 6, somehow Sony remove some video codec, as a result, many apps that i installed are affected,, cant play the video streaming properly.. The TV @ Android 5 was running very well, compatible with most apps. Now it is bad, i have to use another Android TV box to install my paid IPTV app..
I am using X8500C 65" Sony TV..I have used Android TV platform since it was launched at USA...no stranger over the interface..
Sent from Google CHROMEBOOK 11 MODEL 3180 using GAGT
Twilight
My Sony android tv will intermittent reboot
Anyone can advise wat is wrong
vuzuuu
I have been using my Sony Android TV to watch some Taiwanese live news thru YouTube, but, 东森新闻台 and 中天新闻台seemed not working recently, anyone can share some tips which apps allow me to watch 东森新闻live , thanks.
r0_ger
2 Qns
1) How to input Chinese characters into the YouTube apps? Is it even possible?
2) is the Lan port gigabit standard?
Sony 65X8500C. Thanks.
hanseah
2 Qns
I also want to know the answer to no 1. Did u manage to solve it?
kherro
i have a Sony 55 inch X8500e, it will auto switch on from time to time. I tried to switch off the bravia sync, but still have this problem, does anyone have this issue?
Gamma~
I am using KD-55X8500D in my living room and it's connected to my computer via HDMI cable. So now on and off I can switch HDMI port to project different content (computer, digital TV channels, Sony apps etc)
Now I want to move the computer into my study room but would like to still able to access the computer content (browser, folders, files etc, as good as using the computer in the living room) on my TV. My TV is connected to network on LAN whereas computer can be on both LAN and Wifi.
Is there a way to achieve that?
moron+genius
HDMI extender... some can b distributed in Lan network but most need dedicated cat6 cable connection
bleonz
is there WIDI feature on both your tv and computer? thats for mirroring. but if u just want the sharing of files or folders from ur computer to tv, u can use DLNA for it. You may need to download 3rd app/program on your computer to support.
alternatively, if the sony does come with its cloud svc or using 3rd party cloud svc, u can make use of it to sync your files from ur computer. i know samsung smart tv has it.
Solidus_GZ
Anyone pair their Sony Andriod TV on Sonos system? will love to hear your feed back, TIA!
Iron_Maiden
hi Sony users,
I am looking into 55" tv. Anyone got any issue with sony tv?
Hope to hear from u soon
thanks
Eternit
What Android TV apps to recommend if wanna watch China, HK TW drama and movies?
