Sony Days 2015
vuzuuu
There are no 3D Glasses in my 50W800C.
What is your model bro?
In fact, there isn't any glasses in the box.
Mine is also 50W800C.
Will try out the 3D active glasses tonite.
vuzuuu
you bought from courts ??? is the delivery free ?
anyone compared picture quality the W800C with the LG UF770T ? undecided between these 2.
the W800C side bezel really thin, which i like.
They charge me $10 for the delivery.
crandfs
I just passed by Somerset again today, went to check how many glasses they give free, they say only 2, but seem a bit unsure liddat, because they had to check their sales records on computer. I remember when i first ordered they also unsure if the box contains 2 already, so maybe if it does contain 2 already then the other 2 free additional glasses will make up 4.
mrsun18
According to Sony spec for 50W800C, supplied accessories are RMT-TX100P remote and R03 batteries, no 3D glasses mentioned.
kuniyo_keiji
promotions for 50w800c includes the 3d glasses..
it is stated in the promotion booklet,if u go down and take a look at the booklet itself
thomasoon
Why not buy from woodlands domestic instead?
For 50W800C
Woodlands domestic $1480 (including delivery). Self carry will be cheaper
BEST Denki $1499 (on top there is another 2% rebate for OCBC Best Denki Card, 5000 captial land points which is $5 voucher)
So I bought from Bishan Best Denki
thomasoon
I have tried the3D. Pretty good. Didn't watch full movie yet.
I haven't received my touch remote yet. Best Denki told me stock not arrived.
I found that the TV response is a bit slow.
vuzuuu
Have you tried to install any apps on your new Sony tv yet?
I"m thinking to install KODI on mine, but, need some tips and advises for installing.
Any apps which provide HD HK drama series?
thomasoon
Yes. I have installed quite a few of them including Kodi.
Kodi can be found in Play store. You will need to spend time on customisation to get Kodi to be working to your liking.
Some of the Apps are via sideload (Not from Play store). Later I find the link on how to side load apps into the TV. Basically if you know what our apps in Android phone, most of them should work in SONY TV too.
For HK drama, I know there is an app called Dramania. Not sure whether is it HD.
Link on how to side load apps
https://www.youtube.com/watch?v=pfbceDoZDUk
vuzuuu
Bro, can you please share a bit of infos on how to configure the Kodi settings?
I'm mostly into HD/ bluray version of files. Thanks.
thomasoon
I would suggest you to join Facebook group " TV BOX SG", in pinned post, there are many tutorials.
danlim
I saw in GainCity the 65" W850C with some chinese apps like TV CAT(电视猫)
I have it with my XiaoMi Box
anyone tested with LAN and wifi and any lagging effect on Sony android TV?
danlim
using active 3D glasses - glasses comfortable? how long before battery flat?
for short sighted people, there is no clip on
thomasoon
Glasses quite comfortable.
I ONLY tested for 5-10 min, so cannot tell the battery life yet.
