Sony Smartwatch
carlover76
FYI , bishan Sony does not provide alteration of the metal strap, neither does any Sony i guess, yes you have to go to those shops selling watches like City Chain , which i did so, @ $5
Yes, I bought my watch at Sony Centre Sim Lim Square and went to the watch shop at Level 2 for the alteration. =:p
ericwidjaja
i slightly different from you, bought from qoo10 before gg to bishan city chain to do alteration, but i did it 1 day after i got the watch. lol, played with the watch at home first haha
ericwidjaja
and the original metal strap smartwatch, is so BIG, i took out at least 5 portions of the metal parts before it actually fits my hand, and still has loose space in between
ericwidjaja
btw just to share, i'm using the watch naked without any SP, but I do have this fear of scratching the watch, as i'm the kind of person that will sometimes knock my watch against the wall or something, scared man.
carlover76
Then it will be safer to put the SP on. =:p
carlover76
mind sharing the place to get it and damage ? :)
The SP I get might not suit you as it is custom made and it is a combination of Hi Resolution (Crystal Clear) Display with Anti-Finger Print properties so it is very expensive.
The brand is DataFlex and it is called Hi Resolution Anti-Finger Print SP, it cost me $15 for just a small piece on the SmartWatch 2.
You can go for other SP if you prefer to have a cheaper option.
ericwidjaja
$15 is acceptable for me, you haven tell me where to get it... lol
ericwidjaja
those that are using commander app, on the watch mine turns blue, my phone is connected, however when i clicked on commander on my watch, it only shows a black screen with the batt percentage of my phone and the network, thats all, it doesn show the toggles.
anyone knows why ?
carlover76
anyone knows why ?
I do encounter when I put my phone on my back pocket when watching movie then I try to click on the commander app, it does not appear the menu screen and just a black screen. Guess it means the connection is not active, probably a bug in this application.
ericwidjaja
thanks alot for the info, when got time den go put the SP.... now abit lazy... haha,
as for the commander app, hopefully they will fix the bug soon
Cookee
You can also get it from adix82 at Burlington Square. They will cut and put it on for you. I got the matt sp from them for $8. Be careful of dataflex amkhub scroll down and read my post. Before you head down to buy anything from them.
daniel_83
ok Bishan Sony sells the leather strap at $38
available
black no more
brown got 4
ericwidjaja
anybody here knows how to display battery percentage for the SMARTWATCH, not for the phone?
and also , how long you all normally take for a normal charge ? i was surprised when i plugged my watch to charge, it was charging as per normal, but less than 1hour later i went to check on it, the battery symbol stop moving and the battery shows full, but there is a lightning(charge) logo still. does it mean the charging is complete?
thanks in advance
Cookee
thanks in advance
It happened to me on the first charge too. What I did was just too turn on the watch and turn it back off, it will continue charging, but hangs at 99%, and I'll reappear the step above and it'll complete to 100%
ericwidjaja
hmm thats pretty troublesome. ok i'll try for my next charge, as for now, i charged for about 1hour and 30 mins, i unplugged it already and the battery shows full bar. but i'm not sure whether its 100% full
Crexzz
Saw this groupon deal for SW2
Sony SW2 for $219
BUT -
Warranty Info
6 months Groupon local warranty valid from date of delivery
Groupon printout will act as Proof of Purchase
So does this means that the warranty are provided by groupon themselves? Something like in-house warranty?
