Sony WF-1000XM5 wireless earbuds release date, news and leaks
perfectlight
Anyone's XM5 can hear something bouncing inside the earbuds when u on anc? Getting more and more annoyed by it
perfectlight
yea especially when jogging.
Man i miss Jabra.
i realize might be the fitting or the tip itself. i replaced it with some rubber one, still has it. so i decide to change back to the original one. now just order waiting for it.
Joe Maya
I'm looking at the omni silicon eartip.
Toader
Update :
Update contents
" WF-1000XM5 "
[1] The following functions can now be used even when connected to LE Audio.
 - Digital assistant ()
 - Head Tracking ()
[2] Now compatible with Gemini Live.
[3] Audio Sharing with Fast Pair is now supported.
[4] You can now use the "Find Hub" function for left and right headsets.
[5] You can now disable the "Find Hub" feature without using a charging case.
[6] The security of the main unit software has been strengthened.
*To use the digital assistant Head Tracking in LE Audio, after completing this update, delete the pairing information of this headset on the connected device, and then perform pairing again.
Checking the update contents, it is compatible with Gemini Live and has been improved to allow various functions to be used even when using LE Audio.
This appears to have been added as a feature after Android devices made LE Audio connections easier.
In addition, improvements have been made to the ease of use when using the "Find Hub" function, which is unique to completely wireless earphones that are easy to eliminate.
On your smartphone " WF-1000XM5 " Users who are actively using it should definitely update it.
