Starhub Giga
djkopikat
You all have the problem of when in a call, cannot use internet at all? Everytime in call, like no data like tat, cannot surf net, cannot open app that need data
djkopikat
Just to confirm if below is true when switching from gomo to giga:
Get giga sim card.
If mobile has dual sim, put giga sim card in & activate giga temp number.
But don't throw away gomo sim card. Keep inside mobile.
So mobile now has 2 lines - gomo & giga temp number?
Keep using gomo line until giga port over (does not matter take how long :).
When giga ported over, can discard gomo sim card.
Thanks.
In the meantime pls use the temporary giga number to register whatever new user benefits u can get, e.g. Foodpanda shopee etc
Kiwi8
Deluxe Member
I got my giga temp number on 27 nov Friday. My gomo number was deactivated. Giga only ported my old number on 1 dec.so maybe don't switch on a Friday but prepare for 3 to 4 days without your old number.
There is no such thing as 3 to 4 days without your old number. The old humber is still with the old telco sim card. Only change the sim card to the new one once notified that the porting is completed.
GoodBetterBest
I've ported twice and there's no prolong downtime for the number. It's done overnight. It's possible that there is a 1-2 hour outage for the transfer but not in terms of days.
Your case might be a one-off situation.
kazuki666
Finally kena phone call cannot use data... Really is tmd...
A client called me about work, I was trying to use same phone to Google answer for the client, then facepalm remember doesn't work... Kns... :(
Sent from Xiaomi POCOPHONE F1 using GAGT
ekardo
i thot all network have this behaviour one ?
anyway, i am porting out to gomo to try for 6 months..not a data hungry person so see if reception is better with gomo...simcard arriving tomorrow
i.Singaporean
No..
Those with VoLTE (Singtel, Starhub, M1, Circle Life.. maybe got more) use 4G for voice too so you can browse while on call
Those without VoLTE will drop to 3G while on call, in giga's case their 3G no data for some reason
Kiwi8
Deluxe Member
His is not the one-off situation. He did not keep his old sim card in the phone until notified that the porting is done. Of course that would mean he ownself wasn't able to receive the services tagged to his number lah. What did he expect anyway?
For number porting, one should continue to keep the old sim card in the phone, until notified via sms that the porting is complete. By then one can put the new sim card into the phone as the number is now ported to the new card.
meerubus
Must put new sim card from giga to register temp number. You mean no need to do that?
Kiwi8
Deluxe Member
Can also just activate the sim card using the app or website, no need to put in the sim card first.
tks
Today has free 1GB Insta 'n' FB pack when you open their app. Once in a while, they give freebies. That last time was 10GB data free.
Kiwi8
Deluxe Member
10GB is good, especially for those who had just started the service, cos straight away can have excess data to use and rollover most of the unused quota for the next month.
Cos normally for the first month there is 0 rollover.
barnabaskoh
hi, if i have a volte sim card and a non volte simcard in a dual sim card phone, when i answer call, how can i set to be able to still use internet?
Jurong640
Not about volte. If you are using dual SIM phone, you can set which SIM to use data which SIM for voice.
If you got a second SIM that you are using Data, set it to use data from that sim only. Then voice calls will be on your giga SIM.
