State your Note 3 problems here
twosix
I'd suggest resetting the phone and set it up new, if you have funny problems. You probably installed some apps that are causing this but is unaware of. My N3 is rooted and I have no issues like slow, forced closed, etc...
kelvinti
One good example.
I installed Helium, it screwed my icons of few apps. I had to in unstalled it. :
Strange, funny problem caused by some apps but true. ;)
Amsterdan
anyone having the wifi issues, it shows (saved,secured) , however, it cant obtain any ip connection, and keep on refresh and refresh, however the laptop connecting to the ip is working well, is it a firmware issue?
kelvinti
No WiFi issue here using StarHub Fibre at home. It is neither a firmware issue.
Please check your WiFi's Advance Settings.
trd2970
Did u get the unstable or slow wifi warning?turn of the auto network switch in the wifi menu.
JASPER1234
Did anyone experience during call, the other party sound like in a empty room and sometimes also encounter sound of yourself repeating like echo??
Very irritating.. btw i have the noise cancellation on.
IceX
sometimes while listening to songs on my poweramp, the volume will suddenly lower down on its own for like a few seconds. I also hear a "sound"..like voice talk opening that kind of sound:(
Bieffe
on ur router set band to N. Don't put auto.
Then from wifi list forget this network.
Reset router,modem and phone.
Then reconnect.
Can work? All other devices can except N3? Does ur N3 connect any other wifi successfully?
If not then is 90% ur phone is faulty.
By i reckon is 90% ur router.
camholicx
My what apps sometimes doesnt notified me when got new message.
How come like this.is it need to update software?
Bapenigo
Any idea why causes apps/ launcher to crash in note 3?
Because I frequently use instagram and it crashes every now and then. Nova launcher as well.
kelvinti
Try setting all the WhatsApp Vibrations from Default to Short or Long to see if it solves your problem. :)
redchallenge
i have that as well. not the empty room part but the sound repeating. i realized it will happen if i use the call function (as in normal call), but when i do a voip call using apps like whatsapp/line etc, its not there. brought it down to samsung service centre (twice), on both occasions they told me its normal.
JASPER1234
Man it's suck. Thought the new update will solve the problem.
redchallenge
ikr right, damn pissed off when they told me its normal. i mean ive never encountered that from note 1. but i went down to both PS and marina's and they both tell me the same thing.. suck thumb.. if ure using normal call, i would suggest u to talk without earpiece, just the headset, less subjected to noise imo.
gamma7sg
my note 3 when to hospital.
it keeps on restarting infinity. i.e. it will show Galaxy Note 3 screen and it vibrates, like the phone is staring up, then after a while it black out, without showing the samsung animation, and then it will show the Note 3 screen and vibrates again and the process keep on repeating....
i bought it during the launch @ MBS....
kelvinti
Don't worry.
The beautiful nurses at Samsung General Hospital will take care of it. ;)
gt_5454
Don't worry.
Haha that's a good one. Let's hope none of us need to visit them... my note 3 has been very stable so far, even before the recent firmware upgrade
kelvinti
Haha!
Even though we can use Medisave for 1 year, but I rather not utilize it lor. ..;)
