State your Note 3 problems here
kwokweng76
:( unable to output my display to MHL/HDMI LED TV, was working the week b4, now stop working for no reason :s11: anyone encounter same problem?
RequiemDK
I had the exact opposite of your problem, except that I'm using the Allshare Cast Dongle. It wasn't working initially, then suddenly started working. :s13:
Are you using the black MHL adapter or the white MHL 2.0 adapter? I use the black one (relic from my S3 LTE) from time to time and realize that it's very sensitive to how tightly it's plugged in. Sometimes just shaking the cable can cut off the connection and stop it from working. Haven't used the white one though.
kelvinti
First problem after 2 weeks.
My Alarm Clock failed and crashed, followed by sudden shut down. Can't switch on.
I have to remove the battery to restart my Note 3. :(
fuzzybear
ahha kelvin jump from lg and to sammmy
and kanna lemon again aiyor
ivanhoe
My note 3 keeps getting notification for missed call [0] msg [o] battery bal how many percent ? how to disable it ?
zhix
Omg ..I have the exact same problem this morning! Failed Alarm Clock followed by sudden shutdown, then cannot switch on. I also had to remove the battery.
renfred89
i guess this is what we call apoptosis..
kelvinti
Haha!
As a result, I woke up 1/2 late for work yesterday morning. :(
Anyway, let's hope the OTA fixed the problem.
rockyan
only problem is battery draining and drop while charging.happened last 2 weeks back.sent to service centre and now ok already.
kelvinti
good what, if your boss ask you are late, you can blame Samsung.
lol
I did that in the way that I showed him the screen print of the epic Clock fail.
The boss had got nothing to say. ;)
kelvinti
Seriously, how to stop these issue?
Whatsapp and google store also have this msg...
Really cannot take it liao... Agrrrrrrr
Cool bro!
Very simple.
Just go to the Apps Manager, select the app, then Clear Cache for each of those effected app.
After all that, reboot your phone. ;)
You shall see no more problem.
Cheers!
ry0suk1
lag when trying to lock screen, will hang for 1-3sec before screen is lock.
Wifi signal very bad.. keep on disconnecting..
