(Storage) SSD Discussion Thread
doughdough
If your notebook is SATA II then getting a SATA II like the OCZ Vertex 2 is good enough. SATA III SSD will get bottlenecked by your notebook :o
Can recommend me a reliable SSD for G53Sw (I think it supports SATA 3)? but I heard newest sandforce got problems.. can clarify?
ASUSinside
Suspended
G53SW does support SATA III aka SATA 6GB/s. You could consider getting the Vertex 3 or Agility 3 series depending on your budget ;)
Intel® HM65
http://www.intel.com/products/notebook/chipsets/ec-hm65/ec-hm65-overview.htm
ASUS G53sw specs
http://www.asus.com/Notebooks/Gaming_Powerhouse/G53SW/#specifications
Vertex 3
http://www.ocztechnology.com/ocz-vertex-3-sata-iii-2-5-ssd.html
60GB SRP: $239
120GB SRP: $409
240GB SRP: $819
OCZ Agility 3
http://www.ocztechnology.com/ocz-agility-3-sata-iii-2-5-ssd.html
60GB $219
120GB $369
240GB $719
We'll are including a free OCZ 2.5" - 3.5" SSD bracket for our stocks. This bracket is not included in the SSD's original package.
ASUSinside
Suspended
I understand that your company the distro for OCZ products but..:o
Most of the time, won't feel the difference in SSD performances unless doing file transfer or benchmark:)
Just want to share with others a recent benchmark with these 2 drives. Most people have the idea that as long as it uses the same controller performance is also similar. OCZ does their own tweaks to the firmware hence you often see them releasing the latest SF controller SSD before others. The competition has a good product too thus my main intention is to share more information for everyone to make their own brand choices :o
Fully agreed you might not always feel the difference in performance in normal usage but then again if the price difference is minimum wouldn't you want to squeeze every bit of performance out of your purchase? Not forgetting OCZ's frequent updates to their firmware ;)
abuddlah
Just to check, if i were to add in a SSD for my rig. Which brand model of SSD will you guys recommend?
Processor
AMD phenom 925 quad 2.8ghz
Mainboard
MSI 770 G45
Graphics Card
Sapphire Radeon HD5770 1GB Vapor-X DDR5
Memory
Crucial ddr 3 x 2 pcs
Display
LG 2442PA
Storage
WD black 1TB
Optical Storage
Samsung dvd writer
Casing
Coolermaster elite 334 case
PSU
ocz modxstream 500w
OS
Windows 7 Professional
adrianlee
Anvil Storage Utilities Releases New Storage and SSD Benchmark
The software is called Anvil Storage Utilities and we think this report (and introduction) is going to grab the interest of consumers, enthusiasts, reviewers as well as manufacturers alike. Oh did I mention…
FREE Beta Download Here!
Anvil Pro, as it has come to be known, is an ‘all inclusive’ storage utility that is definitely going to strike gold in the storage community. Its ability to test transfer speeds as well as IOPS is as impressive as are the controls that let the user tweak and adjust to find just the right mix in their testing medium. Never before have we had a single benchmark that tests transfer speeds as well as IOPS, the IOPS tests being fully configurable with preset testing scenarios for read, write and mixed IO. For the manufacturer, a simple 0Fill test will display the common RAW data tests shown in specifications whereas, for the hard core enthusiast, we can slide the bar over all the way and see how the SSD reacts to completely incompressible data samples....
http://thessdreview.com/latest-buzz/anvil-storage-utilities-releases-new-storage-and-ssd-benchmark/
More info here
DellSuperman
Yes i understand. So i'm thinking if getting Vertex 2 will be better?
Well, its all up to you... If your budget allows & you have a SATA3 mobo, than go for the higher speed models. If not, I believe the SATA2 models are more than sufficient.
IMHO, you will not really feel a difference between a SATA2 & SATA3 speed unless you are into HUGE files transfer or bench-marking standards.
fantasyrulz
my score for my vertex 3 60 gb
somehow i wonder why my write speed is that low
fantasyrulz
vertex 3 in plugged into marvel 9172 sata 3 chipset
hdd plugged into Intel H61 chipset
fantasyrulz
hmmm how come my score so low ?
its plugged into my sata3
