Suggestion for my rig 2k+
escksu
AMD/ATI is dead to me, bro. Never had a good time with overheating and problematic driver of my HD5870 (i know it's pretty old but still ). May consider for next gpu after 980ti. :D
ITs ok, but do know that Nvidia is just as problematic these days. Heck, even games are super buggy also. Just like that latest batman game.
freshcigar
I am at sls, PSU is out of stock
Can u suggest some good alternative?
Should I go for 750w superflower leadex?
The shop suggest me platinum superflower 650watt
shadow84
Which shop you are at? What out psu they have?
freshcigar
At Tradepac. There isn't any more stock for Leadex 650 watt superflower. Tried cyber mind , pc theme.
Platinum Supeflower 650W- 175
Gold Leadex superflower 750W -162.
I am open to other brand. I don't know much about PSU :/
shadow84
freshcigar
shadow84
I think I am in rush bro. Haha. Planning to get rig assembled today if possible. Can u possibly suggest alternative. Price is not much of an issue (20-30 sgd no choice. ) but I don't want to overkill.
Presuming that you are getting 980ti, 600-650w psu is good le.
From PCT:
Seasonic G650W - $145
FSP Aurum S 600W - $109
Both PCT and cybermind dun have other variants of leadex? How much is the plat 650w frm superflower?
freshcigar
shadow84
Yup. They offered me that.
According to tier list from tomshardware, seasonic g series is tier 2. Bros here normally recommend to go for quality PSU. So I am quite hesitant with that.
It is still a good psu, just that it is non-modular. Anyway, when u have limited choices and not opened to other choices, dun be so niao.
freshcigar
From PCT:
Yes I am getting 980 ti
Platinum superflower /leadex 650watt - 175
Gold superflower leadex 750watt - 164
shadow84
At that price, can consider seasonic x650w. At least, it gives you the options to get custom psu cables. For superflower, its quite hard and ex.
freshcigar
Haha. Sorry for being picky. I know lol.
So hard to make decision when I am not so informed.
freshcigar
I have some problem with installing power cable for my gpu. Been following this great guide:
http://forums.hardwarezone.com.sg/hardware-clinic-knowledge-base-33/your-comprehensive-diy-pc-dummies-guide-4783384-4.html
I am trying to fit in the PCIE cable 2 x 2 pins+6 pins (comes with PSU) to the graphic card but they just don't slot all the way in. the seperated 2 pins is giving much resistance ' fit in to the slot. is it normal and require a bit of push to 'click' into the latch?
Also the MSI 980ti come with 1 cable of 6 pins-8 pins cable which easily fit into the power slots. Is it also advisable to use that cable instead? Because I will only be connection 6 pins from PSU to that 6 pin side of connector and will it give enough power?
Goodshot
Think u better go full modular psu , mine bought $140 is a wtf gfx power cable attached to it
freshcigar
Update !
Ok it is fixed. I am such an idiot lol. The 2 pins has to slot in first then 6 pins.
the psu i got is 750 W leadex gold. I think It is full modular.
my problem right now is, the separated 2-pin from PCIE cable (2+6 pins) won't slot all the way into the gpu while the other 6 with the latch can be pushed to slot in nicely.
Here is the photo of current connection to gpu:
I think I applied enough force, don't wanna break the gpu if use too much force. Can just leave like that?
This is the cable come with gpu
Thanks again bros !
Coool11
Update !
Thanks again bros !
What is the purpose of the cable that came with the GPU?
MoneyFace =p
New Super Flower Leadex Silver using normal modular connectors IIRC... :s12:
Phen8210
Erm.. try slide the 2 pins together with the 6 first.. then put in together. u can see part of the 2 pin lego is sticking out.
GZ on ur pc mate!!
freshcigar
I am not sure abt the purpose of that cable. Even though at one end, it has 8 pins-connector head, there only are 7 pins inside. There is no Pin 8. All good now, I just used PCIE power cable that come with psu.
Finally finish building it lol. phew.
Is it recommended to have my psu Fan and GPU fan facing each other? My rig only have 2 default chasis fans (1 in and 1 out). Will there be enough air flow?
I tried with psu fan facing down but MB cable cant' reach to the socket on psu to connect ><
MoneyFace =p
Ideally downwards. PSU cable should be long enough to reach motherboard connector. Try rerouting.
