Suggestion on building a PC
shadow84
Oh okay noted!!
And yes i will be going for either MSI GTX 1060 6GB O.C V2 TWIN FAN or MSI GTX 1060 Aero ITX DDR5 6GB. Still not sure which 1 to pick on but i think both serves almost the same purpose as long as its GTX 1060?
Thank you.
The cooling on the twin fan is better than Aero. Also, Aero is smaller in size as it is mainly for ITX builds with space constraints.
serverxeon
I would recommend the AMD rx 580.
It's a little inferior to 1060 6gb, but it's cheaper too.
Energy usage RATE is higher but negligible on the electricity bill.
also, Ssd, buy from amazon.
I recommend you buy mx300 it's damn cheap.now.
MoneyFace =p
Your build is good, I can see that you have done your research.
For the monitor I saw on Sitex 2017 brochure there was a dell p2317h going for 199. You can try asking around if you can still get it at that price.
Please justify your claim above... :s22:
How are they even good in the first place?
MoneyFace =p
Claims to support?
spiky0180
Get gtx 1060 6gb. Rx580 is ex. Cheapest is around $400 for the 4gb version, not sure if there are cheaper options. The cheapest gtx 1060 6gb is around $360.
xiaocapri
Yes. Most slightly im going for Gtx 1060. Hopefully to get everything on SLS and settle it as i dont know how to assemble the parts. :(
joshuaho
Another option, go for a 2nd hand 750ti. Carousell ~$60
Yeah joshuaho and Rashkae is right.
In my defence tho, the most value-added gfx card is probably a 1060. That said, paying 300ish bucks just to play dota and have it look pretty seems expensive to me. And shelling 200ish bucks for a 1050 is for a (in my opinion) sub-par gfx card feels off too.
But yea, i'm not all that seasoned in this anyways. so I apologize if I made bad baad advice.
serverxeon
Okay I stand corrected.
1060 is cheaper now. 3 months ago the 1060 was higher than the 580 which was why I made that comment.
Get the 1060 then.
HOWEVER, if you're a gamer and are particular about the screen rate performance, then you should read up on G sync and free sync. In that case you should always pick AMD and freesync
lalala92
I mean if you’re buying stuff in Singapore, going with Asrock + Seasonic PSU is the correct choice.
Cpu, case and gpu branding tbh it’s really up to the individual. Looking at pascal, it doesn’t even matter which brand you get it from, just get the cheapest. If he wants MSI, so be it.
Maybe YOU should elaborate more on what’s “bad”.
Coool11
So you mean, other than Asrock + Seasonic, are incorrect choices? :s22:
tmfwy
I do agree
A 1060 is the most value for money card now
Whether to get 3 or 6gb is very subjective...
For Dota / CSGO / L4D2 and even Overwatch, you can get by with a cheapo graphic card like a GTX750.
IF one wants to get a general purpose card for more demandin games like PUBG / Destiny 2 / Skyrim / Fallout 4, you can't go wrong with a 1060
I've done my own tests and
THOUGH I CAN PLAY PUBG ON AN I3 3RD GEN WITH A GTX750
I will not be happy with the results
So if one is gaming, prioritise budget for at least a 1060 ( you can skip the 970s Overpriced IMO
tmfwy
Perhaps a 2nd hand 970 for < 240ish bucks? I believe 1060 is comparable to a 970?
Never downgrade yourself by going for a 970 instead of a 1060
970 $240 used
1060 $279-$299 new
For about $20-$40 more you get full 3-5yr warranty, a lower TDP of 120W ( Compared to 970's 145W ) and possibly smaller size.
A 10606gb is closer to a 980 with a low tdp for abit more..
tmfwy
You can try Infinity
They assemble for you in shop right in front of your eyes, rather than going somewhere behind...
MoneyFace =p
Seems that you are trying to digress what was meant in your initial post.
By telling TS that, you are implying all the parts chosen are of best value and performance. Which is apparently not the case and you are misleading TS. Form of encouragement - Yes. Dishonesty - NO.
1. Core i5 7th gen is a big NO NO nowadays especially when Core i3 8th gen has already succeeded it with identical specs at much lower price. i.e. Intel Core i3-8100 = Core i5-7500 from just $180+
2. MSI Aero ITX graphics card has lower cooling capability due to its compactness and single fan and it is not the cheapest yet decent GTX 1060 TS can find on the market. He could have otherwise better opt for Galax GTX 1060 OC with twin fans and remarkable temps.
3. Not all seasonic PSUs are great. Their S12II/M12II are only so so as compared to their higher end series.
4. CM Elite 430 has such an outdated specs and design by today's standards. There are way better options there.
tmfwy
I totally disagree with this
Asrock, i will put it in the same space as MSI / BIOSTAR
Gigabyte higher up
BUt Asus if at all possible
I used to like GIgabyte coz they had the One-Click Installs when you pop in the CD
Also not Seasonic alone. Plenty of other PSUs out there in the market whether cheapo or expensive, up to you
Personally running on a 230w PSU for my I7 10606gb setup and a 450w for my i7 1070ti setup.
You don't need to go overboard for ITX setups. Just get something QUIET. 500W is more than sufficient for a mid-range setup.
MoneyFace =p
Gigabyte higher up
ASUS, Gigabyte, MSI and ASRock are the big top 4. Biostar should be linked up with ECS and the tiong brands...
