[SUMMARY] Gaming Monitor Recommendations
wei406015
anyone have monitor with this brand? "SuperSolid" are they another prism type of brand in singapore
Lit3s
anyone on BenQ monitors? Good?
Saw this BenQ EL2870U 4k monitor pretty decent price.
The 27" EW2780 also pretty good price.
Looking for a 27"-30" below $400 bucks
elskade
Supersolid P24 PRO = Prism+ PG240?
Their Lazada pictures same. Only different colour for the lights �
Sent from OnePlus HD1900 using GAGT
polowalrus
Prism = rebranded budget Korean monitors? Not sure if they use the highest rated panels?
Dunno if VA panels are worth it at this price over IPS
Limexx
higher rated panels means better colors? will the other specs like response time and refresh rate be different too?
jasonwsc
buying a monitor tmrw, Aorus FI27QP or 27GL850?
Please help!
Go read the review on the first page, no one going to spoonfeed you all the info.
If possible, read the reviews for each monitor. The same panel can be tuned differently by different manufacturers, but the base performance is the same.
PRISM+ uses older Samsung panels, a.k.a their VA stuff are older than the newest gen Samsung G series panels.
Can help to confirm whether Panda panel really low viewing angle (high IPS glow)
I decided to just buy a monitor with the AUO panel. Can't be bothered to play panel lottery with Panda.
polowalrus
Trying out getting monitor from taobao. Much much cheaper than in sg. Let's see how my panel lottery goes
supertramp
I got list a few Dell and Alienware leh.
But mostly cos Dell don't make good gaming monitors at the lower end. Most people aren't paying $300 for a 1080p TN S2421HGF.
The Dell S2721DGF looks pretty good though. LG nano IPS 1440p panel but still a bit too expensive. I personally think Dell QC is a bit better than Acer. :s13:
Thanks for mentioning the Dell S2721DGF. Quite a good deal imo. Almost dropped my bucks on the LG 27GL850.
jxjxjxa
Hey bro, think you misunderstood me. I have done extensive research for days but honestly just not sure between the 2 which is better. So was just asking for input. Not being a lazy bum
Navillera
Buy the 27GL850
Sent from Google PIXEL 4 XL using GAGT
polowalrus
Which one u getting?
One of the LG nano ips monitors. Probably the off branded ones. Still cheaper than prism for 27" 165hz IPS. Around 320$ and I estimate 40$ for shipping.
But this is a gamble for panel lottery and no warranty so its not advised
Limexx
What does winning the panel lottery mean? Better colors? No dead pixel?
