Surface Pro (5)
htngwilliam
Actually can consider surface pro 4. Quite good deal with pen somemore. I read surface pro 4 and 5 kind of little differences
evq
Do u all use screen protectors or TP for surface device?
I only use skin on the back of my SP4
https://dbrand.com/
This is to prevent scratches on the back of the device if i rest it on the table.
Nvr use a screen protector or any case. The feel will not be the same if writing or drawing on it. And case adds weight, defect the purpose of getting a surface in the first place. That's just me. I use a laptop bag.
Someone crack his screen even with a UAG hard case. Just handle with case.
htngwilliam
https://dbrand.com/
Can surface pro 4 skin fit surface pro 5?
evq
On the outside, both r surprised to be the same. I will get the skin even if it is only meant for sp4
R u intending to get sp4 or the new SP?
ExArchz
I see. I read alot of comments on how TP makes touch screen a little off.
Im considering surface pro skin too. Im using one on my phone. Idk if pro 4 one fits the pro 2017 since they are the same externally just the corners abit rounded
evq
For me, since I haven't get the new SP, I will wait for dbrand to come out, but if there's a need, I will still get the skin for sp4
htngwilliam
Not sure which model to get. Seems like no much difference so thinking of surface pro 4
evq
Batt life is the most significant improvement. That's one of the main reason why I m upgrading. :D
Anyway, if this is ur new Surface product, go for SP4.
htngwilliam
I wrote to dbrands. They didn't say when they will release skins for SP5
Vassago
Hey guys , I am stuck setting up surface pro 2017. It is stuck at scale files to one drive? I said yes or no. The screen still did not proceed to next page.
SpeedWeed
the lte is important and the improved battery life
