The Plastic Model kit hobby thread
virtualape
Stargek close shop, where you guys get Tamiya stuff from these days?
Meowtiko
moi ish noob
just buyed SD gundam the other day
simi panel line sanding detail painting etc all dont know, went into a gunpla/hobby shop full of tools very intimidating
:frown:
PikaPika33
High Honorary Member
Maybe check out vallejo water based paints with airbrush. Vallejo Air is for airbrushing.
i get some taiwan(?) water base paint from the shop in chinatown
i prefer hand brush i think
airbrush too chim liao
PikaPika33
moi ish noob
:frown:
sd is goot, my first also sd
i just hate the small stickers, my fat buibui sweaty fingers destroy the sticker set :(
start if a good nipper, and work from them :(
the rest can slowly learn, like me still learning :(
Meowtiko
I got black gundam marker for panel line but ish very bad, keep stain the plastic and I use finger wipe, today went to buy the tamiya panel liner and the thinner, saw on youtube like not bad to use, this weekend try on cheap cheap HG buyed from carousell
stickers keep falling off also :s15:
Itsthatguy
I think the chinatown shop (hammerhouse) is the warhammer 40K shop that sells an array of different brand paints.
Ak interactive 3G and Vallejo are water based paints that are quite compatible.
Share with you this vid. The usage of airbrush for simple highlight base for brush painting.
tarui04
moi ish noob
:frown:
Just do whatever you like.
Don't listen to others telling you you should this and that.
PikaPika33
marker pen very thick, sure will stain.
just clean with cotton butt + some cleanser can liao
PikaPika33
no ba
is the one near to chinatown complex
they sell gunpla, girlpla and china mecha
thanks for sharing
Song Bro
I think have to improve my skills first
sometimes i put small parts together also difficult, buibui fingers :(
Ya. Bought a couple of these.
Dun dare to put together for the same reason. 32mm leh... :(
