Thinning Hair problem
Ironaddict
Let's try to update this to help all bro who are sufferring from hairloss/thinning. Appreciate all bro input, espcially those who just got the medication recently.
thanks.
1) Propcia 1mg - Original
NSC $63.84 for 28 tablets
2) Propcia 1mg - Generic
3) Proscar 5mg
4) Minoxidil 2%
5) Minoxidil 5%
bought 30 tabs of proscar 5mg for about 170 dollars including consultation at a jurong general clinic
tildveryn
If you follow the ritual daily you should see some results. You can't just depend on the saloon treatment. The home programm is more important.
for keratease, i tried the shampoo and spray for hairloss together with monthly saloon treatment...
home program is cheap... saloon one time treatment for hair is over $100
Knight_Rider
Like I said home ritual is more important. The ampoules and serum is still essential even you go for treatment. I find the conditioner very important. The wrong one will make you lose more hair.
gohjlb
Help i in danger of hair loss.
But i don't want to sign up with their package. it so expensive.
$900+ for 10 session or 3800+ for 24 session at jean yip group ...
Anyone got any Oily scalp hair product(those apply natural herb)?
Recommend me . i be most appreciated!
Btw, i am only 23 and i losing hair a lot due to heritage from family.
Knight_Rider
Page 293 post 4389 got pic got address........ and dun use hot wqater to wash hair. Will produce more oil.
Knight_Rider
conditioner important?
I use follizin because it adds moisture to the hair and scalp. Nioxin and follizin is the only two scalp treatment conditioner. But Nioxin is too rich for me and drop more hair so I can only use follizin. A lot of people say guys no need conditioner but it gets dry after all the stuff you put on the hair so I really need that conditioner.
gohjlb
my hair too short. how to not let scalp touch conditioner. very hard-.-
Knight_Rider
If your hair is very short then can skip conditioner. Or you can bend down head facing the floor. use a small amount and rub on palm first (shampoo also the same but no need to bend down. Do not pour the shampoo on hair and work up the foam). Then apply.
gohjlb
omg i always pour shampoo on hair then apply lol...
Conditioner need to opposite oh... then haha.
need to do push-ups while i do conditioner applying...
Knight_Rider
Actually not recommended as will put unnecessary stress on the hair. Young ok but old uncle like me got to be more giao even on the simplest step. So for shampoo I pour on my hand first and rub. :D
Dallen
Where can I bought kerastase in singapore
Ampoules are sealed vial of goodness (Vitamins + Proteins and other tech) that goes directly to the root. Kerastase helps prevent the accumulation and hardening of collagenas well. LA BIOSTHETIQUE is more on nutrients and
premature cell death.
Kerastase seems to work very well on me without Proscar or Minoxidil (I dun like those and dun ask me why). The big box has 42 bottles for 1.5 months application. 2 box normally does the trick. After that can do maintainence using La Bio/herbal then go back to Kerastase (no need daily dose).
As for serum (intensive follicle energizer) you need to apply every night after washing hair.
Aminexil GL M
BIO-FANELAN REGENERANT PREMIUM
LA BIOSTHETIQUE Paris - METHODE REGENERANTE
Dallen
what band of serum r u using ?
