Thinning Hair problem
satelitte212
hi guys. just to help out the rest who are considering to get on propecia.
I recently got my propecia from Changi Hosptial. they now carry generic propecia, Finas 1 (price $51/30 tabs) compared to previous where they only carry the original propecia, Merck ($90/30 tabs).
im in my 2nd month of propecia. ill be switching to proscar once i see much improvement and stability.
Asymtope
any idea who's the manufacturer?
tildveryn
I tried Rene, Phyto and I think Rene is better. Phyto got no effect on me.
Effective as it claims. 2 box of ampules comfirm your hair is jungle. 1 box is 42 so is 1.5 month and can see results liao. Night I use serum and thats about it. I dun take oral pills and I dun use minoxidil as well. Conditioner I use follizin.
Maintanence I use La Bio and the herbal thingy.
Rene? where to get that? shampoo or serum?
badkham07
anyone has the latest pricing for the following pills from Singapore clinic?
1) Propcia 1mg (both original and generic)
2) Proscar 5mg
3) Minoxidil 2%
4) Minoxidil 5%
I am going to BKK next week and will be getting from there if the pricing is very difference.
For bro who are interested to tap along, we might be able to work out something. I wont be charging extra, but because I would be using credit card for payment, so if keen, there will be a currency conversion charge incurred.
Any bro who bgt the above recently, please advise, or PM me if not convenient to disclose.
thanks.
unwanted
Actually the most important thing one has to do is.
Wash your scalp thoroughly. Wash twice if necessary.
After you wash, press your scalp see if it's oily, if yes, wash again
After I stopped all the air products like spray wax etc.
My hair dropping stopped.
I didn't cont taking any drugs as well but I used a biotin shampoo to thicken the follicles and hair.
badkham07
Let's try to update this to help all bro who are sufferring from hairloss/thinning. Appreciate all bro input, espcially those who just got the medication recently.
thanks.
1) Propcia 1mg - Original
NSC $63.84 for 28 tablets
2) Propcia 1mg - Generic
3) Proscar 5mg
4) Minoxidil 2%
5) Minoxidil 5%
marcus_88
For the Rene's FORTICEA stimulating shampoo. Can it be used for everyday wash? Meaning once in the morning and at night?
For Follizin, they only have 2 products right? The Cleanser and the small bottle thingy<- which I presume to be the serum/conditioner?
Currently I am using the Ba Wang anti-hair fall shampoo. Just started only, but looking for alternatives.
Knight_Rider
Rene's FORTICEA is gonna dry up your hair. I would reccommend Follizin over Rene. Yes the small bottle is the serum. They have more products just that it's not listed in the website. I am using the conditioner (called The Moisturizer) since it's the only alternative to Nioxin which can touch the scalp. And Nioxin is pretty much useless. Follizin also has ampules, infra-red machine and stuff that can't be search on the web. Check with the distro for the retail shops. There's a shop in clementi Ave 2 that carries almost the full range and has some promo. Follizin | Glamour Salon System
marcus_88
Thanks man! SO i guess Follizin is much better than Rene right? I will try out the Follizin then!
Knight_Rider
Because Rene got no conditioner so they recc alt use of FORTICEA and TONUCIA. You can use Rene with follizin conditioner and see the result. If not suitable then change the shampoo to follizin. I find Kerastase shampoo works well with follizin conditioner but eventually it's the ampules that you put everyday that is important. The serum at night contributes the other 50%
So morning wash is a fast one just to clean the hair (no warm water) apply ampoules. Blow dry ( no high heat). Night fast wash to get rid dirt rinse followed by a longer wash with massage. Remember no warm/hot water for the rinse as it will aid the production of oil. Blow dry as well and follow by serum ( no need whole head just the important points). A wet head to bed is a recipe to hair loss. Blow dry is troublesome but essential.
Let me know if it helps.
marcus_88
Cool! Thanks for the detailed writeup! I guess I will try the Rene's shampoo with Follizin first. What is this ampoules that you are refering to? My idea was just wash, condition, and serum every week.
Knight_Rider
Ampoules are sealed vial of goodness (Vitamins + Proteins and other tech) that goes directly to the root. Kerastase helps prevent the accumulation and hardening of collagenas well. LA BIOSTHETIQUE is more on nutrients and
premature cell death.
Kerastase seems to work very well on me without Proscar or Minoxidil (I dun like those and dun ask me why). The big box has 42 bottles for 1.5 months application. 2 box normally does the trick. After that can do maintainence using La Bio/herbal then go back to Kerastase (no need daily dose).
As for serum (intensive follicle energizer) you need to apply every night after washing hair.
Aminexil GL M
BIO-FANELAN REGENERANT PREMIUM
LA BIOSTHETIQUE Paris - METHODE REGENERANTE
tildveryn
Keratease treatment doesnt seem to work well for me... each session is around $128...tried half a year liao...
think so far... yun nam is still ok... at least got some results but think its too expensive also..
Knight_Rider
If you follow the ritual daily you should see some results. You can't just depend on the saloon treatment. The home programm is more important.
