Thinning Hair problem
started to spot some young guys who shaved down recently (not because of NS) but because of receding hairline and topdown balding.
i guess that requires confidence...
decibel.
I was using regenepure Dr but apparently the company have changed the formula and ketaconazole is no longer the 3rd ingredient on the list (now 9th). It feels different and no longer has the "tingling" sensation after you shampoo your hair.
Anyone else has a good 1% ketaconazole shampoo to intro? Think Nizoral is easily avail but some of the chemicals are quite harsh
I recently started this but notice more hair drop off but it feels good. Do you know if that's normal?
Sent from HUAWEI VOG-L29 using GAGT
decibel.
Hi guys I notice under bright light when I come back my hair can actually see my scalp is it hair loss?
eyz
RidgeCrest Herbals Hair ReVive
My wife is using this product for hairloss, and it's effective for her.
She started with 4 capsules per day for 2 months, and had seen tremendous improvement. She had now reduced to 2 capsules per day accordingly to the recommendation.
She also mentioned that her nails had grown stronger.
For women hairloss only.
qhong61
Any side effects?
trickle_on
Glad to share that I have recovered from hairloss which was caused by allergic reaction. Unfortunately, have quite a bit of leftover 1mg finasteride cos I personally stopped taking about a couple of months ago when I realised my hairloss was temporary.
Shampoos that have been in my rotation since are Neutrogena Coal Tar and Yves Rocher Purity. Keeps my scalp clean and removes buildup.
crlsberg
I think i have similar issue. What are u allergy on?
Cumzilla
i use grafen shampoo and i feel like got difference la, not just temporary
pls be careful, got a lot of scams and fake versions
I get mine from shopee cause they have an official store there
thanks for the recommendation, did u only get the root booster?
popdod
For those thinking of getting hair transplant...or thinking having propecia.
you might wanna hold off the plan for 1 or 2yrs...if you can wait.
Some of the hair loss "cure" in the pipleline.
Phase 3 means human trials.
:s12: :o :s12:
