Thinning Hair problem
Wilb87
Toppik has no damage, it is just like fibre and it entangle around your thin hair making it look more thick and fuller, it really has a good effect, there are also a lot of color to choose from. You can use it to mask your thin hair until you get some good effect from treatments.
http://www.hairlosstalk.com/cosmeticops/toppik/index.htm
I not really sure about malaysia, cause i lived in singapore, maybe you can check around? There are also some similar products, some like brush where you apply coating on your thinner hair to make them look thicker :)
arianwen
Wilb87 said:
Are you a female? Female cant take or comes in contact with Propecia, Proscar and Avodart. It is okay to have sexual intercourse while taking propecia. However to play safe, if you would like to have a baby, you may stop your regime for like 2 days? Although no bad effects were shown and no bad results. It is not that bad as you think.. Just keep those tablets away from females.
nah.. i am a male.. .. how about proscar then? any side effects as mentioned earlier?
Wilb87
Proscar side effects are very low at around 1%, most of them with the side effects goes off, after a while on the drug.
-Low sexual drive
-Erectile Dysfunction
-Breast growth
This % are really small lah, Even if you suffer from the side effects, once you stop the drug, it will goes off. So no worry :). I am on propecia too. The more you think about the side effects, there will be a mental block, which may lead you to think that you are suffering from side effects from the drug.
podskinz
for those of you who bought rogaine foam version from me .. if you guys want..can have a mass meetup for collection..if possible? thanks!
podskinz
alex_master276 said:
yes, bought rogaine from podskinz. very smooth deal. beginning to use it now, see how it works for me.
Thanks for the thumbs up : ) Oh yah try to keep the can in a normal temperature area..not too warm or facing direct sunlight if not the foam might turn into liquid ..ive read this from some forum.
And to prevent it from being absorbed into your fingers too quickly during application, one gd tip is to rinse your hands with normal tap water first.
Cheers bro
Anakin1982
Hi Isopropyl, think i will start on finasteride on top of my minoxidil. I was reading thru the previous pages on the thread to learn more cos tis is my first time with the drug. So jus to re-cap what have been said (pls correct me if i'm wrong):
Proscar & Propecia are essentially the same drug, jus tat diving proscar into 5 parts will save me money
Can i get proscar in s'pore (get a precription from my doc in NSC) or do i have to get it from malaysia? cos from what i read, many of u seem to be heading JB to get the drug... is it significantly cheaper?
So how many months of supply do i nd to buy & roughly how much?
Thanx alot for the help.... tis is my first time trying the drug so i'll nd as much as info as possible
Isopropyl
1) correct. divide it into 4 or 5parts willl do.
2) yes. you can get in singapore. just get a prescription in any clinic then buy it at most pharmacy. if i not wrong, JB is about $30plus cheaper. also, you do not need any prescription.
4) you need to take the drugs as long as you want it to work. in another word, for you whole life or until something near to a cure is found. one box is 30tabs. so divide it into 4 or 5parts will last you 4 to 5months. how many box you want to get at once, depend on yourself. maybe one box first just to try it out.
Happy7
I would like to know will glucosamine improve hair loss? I am taking that at the moment because of joints problems. I do think that glucosamine will help combating hair loss because I read that it will improve nails, hair and cartiledge.
Anakin1982
Thanx Isopropyl
yeah i went to check out at Unity pharmacy today & the pharmacist told me it's ard $115 and i wld need a doc prescription
guess i'll start with one box first... since one month supply divided by 4-5 parts wld last me around 4-5 months. if it works & i nd it for long term, then i'll cross over to get it
once again thanx Isopropyl!
Wilb87
Selling a bottle of Regaine 5% Minoxidil.
Prescribed, opened, but unused.
Looking between 60 to 70$
guardian sells a bottle for $69/$70.. so there isn't much of a price diff..
Wilb87
My lasercomb will be coming soon, will be putting it together with my propecia. Will keep you guys with my result.
browniechenryc
Advice needed on Tricomin
Read an article which says "Tricomin has been shown in clinical trials to stimulate growth. It uses specific Copper Peptides to stimulate naturally dormant follicles into their growth phases, effectively countering the damaging work of DHT. Tricomin products can be used effectively with other treatments including Rogaine and Propecia, providing additional benefit to the follicle and surrounding environment".
Has anyone tried this? Is it effective? Where to order this in Singapore? Thinking of trying this alongside my regime of propecia, minoxidil and Nizoral.Also, do I have to use Tricomin forever just like minioxidil/propecia to maintain/grow hair?
Any advice will be very very much appreciated :look:
Asymtope
OMG!!! u bought the $1000+ laser comb??
