Thinning Hair problem
Erniemaster
I see. Any improvement?
Been on it nearing 8 months. Hair loss has slowed/halt (Miniturization Reduced). But as for regrowth, Very Minimal. So my dermatologist has suggest to combine with oral Minoxidil 1MG Daily, been on it for 11 days.
I have Serbohic Dermatitis, need to have it controlled, so best to avoid topicals.
RyanJ
I just went NSC for consultation, given Rogaine, and finasteride. So far I have not taken finasteride yet, not sure if I want to take the risk of having side effect. Any advise?
Instead of taking the oral pill, there are topical finasteride preparations ( scalp lotions etc ) made by compounding pharmacists . Will still require a doctor's prescription
fxsg123
Two qns
1) I just check Rogaine foam vs liquid which is better?
2) Rogaine (foam/liquid) good enough or combine with revita shampoo better? Revita seem very exp, haha
3) those hair care like yunnan or 101 can believe? Will help?
krazynoobie
Two qns
Foam is better somehow. i think it spreads more evenly across the scalp.
combine with revita shampoo better for sure. no choice, haircare is expensive. the ntuc sell $20 those type dont work. buy the big bottle one, more value for money and can use for a long time. leave it on for 5mins and gently massage ur scalp during use.
yunan dont bother. scam. you dont see user recommending which tell you it doesnt works. only their own ads promoting.
darthstar
Used to used nizoral but stopped long time ago, wondering if anyone still using nizoral shampoo with 2% kercotone?
Been hearing some good reviews on this AFC Shokaigan shampoo also, anyone using?
hadesdrive97
Btw guys, even places like beijing 101 and yunnam hair care have been found that their products and herbal **** contain FDA approved topical Minoxidil lmao. Just goes to show that if one were to see any results from them, it is most likely due to the minoxidil. Do not be scammed by them. The other herbal ingredients doesn’t do jack **** and even they need to rely on Minoxidil to try and give some results to those people.
I can’t post the link here, so just Google search ‘HSA detects an undeclared westernal medicine in the Beijing 101 hair tonic which contains Minoxidil’. You can thank me later.
hadesdrive97
Hey bro which dermatologist did you go to? I wanna get oral minox prescription as well.
