Thinning Hair problem
revenant
having use finasteride for the past 2 years i noticed my hairline is still decently protected.
for finasteride to be more effective, is best to use it when one is younger.
as for the male fertility side effects, just don't take it on the days one need to plan for a baby.
got 2 friends that avoid taking finasteride, one is a single (don't know when can get a partner), another one is in the process of getting a BTO and haven't had wedding dinner yet.
now i got more hair than both of them.
the side effect of finasteride is, tougher to get hard or tougher to get baby?
simon_84
Is more of the hardness issue for singles.
Just need to stop the intake for 1 or 2 days and it should be sufficient.
For those above 35, better to stop at least 2 days.
tesarise
Anybody can recommend a reliable Regaine/Rogaine foam seller on Lazada?
The prices are about half that of the liquid version at Watsons and Guardian, scare it's not authentic
blizzaro3
Carousell seller seems to be selling it cheaper than Lazada
hereiam7788
Post hair transplant in Singapore
Yes - the transplanted hair can grow back, since the whole hair follicle is transplanted onto your scalp.
In fact, after the first few weeks, your transplanted hair WILL drop out. This is normal.
But you must maintain one la, like take finasteride medical, use minoxidil shampoo. Otherwise, there is a chance that what caused your hair loss in the first place will cause your transplanted hair to keep falling out as well.
Source:
The Comprehensive Guide to Hair Transplant in Singapore (2020)
there is no such thing as minoxidil shampoo la...
XiongIsMyNick
Two qns
1) I just check Rogaine foam vs liquid which is better?
2) Rogaine (foam/liquid) good enough or combine with revita shampoo better? Revita seem very exp, haha
3) those hair care like yunnan or 101 can believe? Will help?
yunnan or b101.. they just wash ur scalp to make it clean.
some of their herbs or meds come with minoxidil content, i think somewhere online it was reported lol
Don't waste ur money in that way
foo9883
Finasteride must be prescribed by doctor is it? Don't have over the counter ones
fanclub
hi, i am new here. i just start to use minoxidil spray and finasteride 1MG medication. I really hope these 2 treatment can work for my hair loss. Did any of you have tried it for months/years and it able to help you to grow your hair back? :)
revenant
tried both for about a year now, doesn't help
simon_84
Finasteride helps a lot to reduce hair loss for me.
To a point that I don't even bother with minoxidil spray now.
What is the stage of your hair loss now ?
If you start during the receding hair line stage, still got hope to prevent a center mass fall out.
rocky86
Hi Bro, any recommendation for Finasteride? is oral pill?
simon_84
Is an oral pill, better to see a doctor from national skin center first and get a prescription so that you can get cheaper over the counter pill in the future.
Cause your issue may not be male pattern hair loss.
I get my pills from the following hardware zone user.
XiongIsMyNick
