Tips to build a dust-resistant PC?
haylui
Convert one of your room to a class 100 cleanroom, complete with humidity controllers and hepa filters. That should keep the dust and rust away. I worked in a clean room environment and my work PC that is turned on 24/7 has no dust or rust after using it for 3 years.
No need la. Build a cabinet that has hepa filter in it can liao. Clean cabinet not need entire room.
watzup_ken
Use pc in ac environment, lesser dust
But still good to do some maintenance like ac systems periodically for it to breath easy
I feel this is not true. AC environment don't equate to lesser dust. Dust is a generally human dead skin, so unless you don't stay in the room and keep the room door closed, you will bound to have dust.
