TPG Technical Discussion Thread
carboy00
Thanks the IMS access point worked for VOLTE. But now I have another problem where the TPG sim card I have becomes deactivated when I tried to assign it for Dial and my second sim card Circles for Internet. Do you have the same problem? :(
Redmi Note 5A supports only 4G on SIM 1 and 3G on SIM 2. So if you put the TPG as SIM 2, it will not work since TPG doesn't fall back on 3G which it does not have the network for it, hence no signal. Only way to get it to work is putting your TPG on SIM 1 and assigning it Internet instead and your Circles SIM to fallback as dial since it will be on 3G
No issue on my side as I assign the TPG (4G SIM 1) for Internet and SingTel prepaid (3G SIM 2) for dial.
Sent from Xiaomi Mi A2 using GAGT
hanayorisg
Just got Xiaomi POCOphone f1 6G+128G
I put the SIM card 1 as circle life card and SIM card 2 as TPG
Now circle life both internet, call, works well. But TPG totally not well
Anyone can help how to set up for TPG, need to switch 2 SIM card?
MIUI version 10.2.2.0 ( PEJMIXM) (I have upgrade to the latest version)
confused
I have the exact same model and miui. Yes I put TPG in SIM 1 and the other card as SIM 2 and it works for TPG call, sms, internet. You set the APN and *#*#86583#*#* code already?
cruizer_ph
My Huawei P20 Pro just updated (OTA) to firmware 9.0.0.197. After this, the TPG sim card in slot #2 suddenly supported VoLTE. I was able to successfully place a phone call using this.
Jacky2000
how to set up dual sim using TPG?
I'm using Samsung A6 phone, insert TPG into SIM1 and use for data only and Singtel Prepaid card on SIM 2 for phone call.
But the network cannot be set, I set singtel 4G/3G/LTE, then TPG become 2G
There's only a few choice in the phone:
LTE/4G/3G
4G/3G
2G
Boltstorm
LTE/4G/3G
4G/3G
2G
Should be your phone limitation. Even for my Note 8 only 1 card can be on 4G at a time, the other will be 3G
renfred89
huh, i thought dual 4G standby already what, it was activated via software update some time back......
Elon Jobs
I tried my TPG SIM card on my iPad Pro, data was fine, but can’t receive or send SMS (except for iMessage, which technically doesn’t count since it’s using data).
However, once I took out the SIM card and put it into an iPhone, I can start receiving and sending SMS.
oceanicmanta
unable to receive OTP SMS for my TPG card all of a sudden ... using Xiaomi phone
anyone has same problem ?
KSeet
Any one can share some light on why I can't connect to the TPG network on my old S5 LTE A model from Korea? Thanks!
KSeet
If you are using a samsung phone. Go dialpad press *#0011#. Can see the band you are connected to.
Thanks for this! My S5 can now connect to the network after I select the LTE B8 specifically. But I cannot receive SMS or make calls. Hence WhatsApp cannot use. How ah?
