TPG Technical Discussion Thread
lenseview
Thanks for this! My S5 can now connect to the network after I select the LTE B8 specifically. But I cannot receive SMS or make calls. Hence WhatsApp cannot use. How ah?
For sms, try setting the correct sms center. For voice call, need volte and tpg to support the handset.
grapewall
No signal when taking trains from bishan to orchard and bishan to bouna vista. Guess they're not ready for tunnels yet.
mac_t13
I saw it on the apn setting, the listing there have samsung galaxy note 3. Is there any other listing that shown supported devices?
cscs3
It should work for data if your phone support LTE b8 and b20. Voice call need VoLTE support, not every phone has this.
renfred89
Not supported. Have u looked at the list of supported devices?
my bad. i thought u were referring to VoLTE network.
For VoLTE, it is not supported, hence no voice call supported.
what is the android version you are having now?
renfred89
Really? I just started to use TPG.. i tot it is one of those virtual operators...
haha, there is no i thought. when you sign up that time, you should have read the agreement.
TPG is not a virtual operator arh..
ahyeo
Can send and receive sms to another TPG or Telco number. But cannot receive OTP sms from google, grab etc etc....
Anyone having same problem too?
