TPG Technical Discussion Thread
RVS_SK
anyone using TPG with LG v20, cannot voice call even if VoLTE enable? any setting to enable voice call, my LG v20 is already update to oreo...
8-lane
TPG just added Samsung Galaxy A70 to their list of supported VoLTE phones...
penyekz
Can you please advise on the mifi settings like pdp type - IPv4 or IPv6, apn type - static or dynamic, auth type - chap, pap or none.
I have a TP link m7650. I'm only getting speeds of 0.6 mbps at the moment. Is this typical?
kazuki666
They should add the xiaomi phones too because they work haha
Sent from Xiaomi POCOPHONE F1 using GAGT
kashix
They Cap mifi speed to 1mbps. Sounds about right.
Sent from Google PIXEL 3A using GAGT
jc777
Anybody successfully get the call function working on Redmi 6A? Cannot seems to get it working.
JustDoLor
Only 0.000001% of phones works during trial lah.... If make all phones works now, or before they can bill u, then in no time TPG uplorry lah.....
Lemmieeeee
Anyone has issue when using s8+? i followed steps to manually add network. but i cant serve website nor tethering.
eighthours
Mi Max can make VoLTE calls!
Now using both $0 circle life and $0 tpg. While still be able to use 64gb micro sd.
shiok ah
Hi bro can share how? I can't even connect to the network. Have tried turning off auto connect. Tried manual find also only see the big 3 telco. Am using mi max as well.
Remless
Seems that TPG Volte calls to landlines are down. All incoming calls (Both landline and mobile) are still working. To other mobile phones are also ok.
Tried with Pocophone F1, Mi Max 2 and Samsung A10. (All 3 TPG lines did not exceed the 20mins per mth quota)
Remless
I guess to be fair, it's really to hard to keep track which phones can use. Soooo many new phones are released every month.
I think Xiaomi phones are not officially supported by TPG, that's why they are not in the official support list. Those in the list work as it is w/o further user interventions, where XM phones need to set the settings in dialer.
I think all volte-phones have some kind of 'whitelist' or hidden settings/profiles to make volte of a certain carrier work. XM phones just have this wonderful 'disable carrier check' function to allow volte from all carriers.
Some oneplus phone users also managed to get TPG volte working on their oneplus phones using the method:
https://forum.xda-developers.com/oneplus-5t/how-to/guide-volte-vowifi-german-carriers-t3817542
https://www.youtube.com/watch?v=ALmpaiahKas
My older volte-enabled samsung phones and LG ones cannot work (only data works).
GenerationX
Actually redmi 6A is cheap and good for this tpg network. Can call, SMS and data. It uses both tpg lte band (8 and 40). Just follow the setup can use volte leh. Can google. Now redmi 6A only $109 (father's day promo till tomorrow)
Sent from Samsung SM-G955F using GAGT
Where can buy in sg? I go xiaomi site click buy it link me to lazada my page..
