TPG Technical Discussion Thread
Anyone the volte icon keeps going on and off and on again???
Pocophone here
lenseview
How do you know which band you are using? I thought it is internal and you won't know unless you root the device.
B40 is almost non existent. B8 is the band covering 95%.
If you are using a samsung phone. Go dialpad press *#0011#. Can see the band you are connected to.
virus2977
My max 3 got volte for TPG. I use secret code then volte appear....lol sic *#*#86583#*#*
Sent from Xiaomi MI MAX 3 using GAGT
confused
Pocophone here
Did you keep receiving SMS from TPG that your phone is capable of 4G mobile phone calling, then it's nothing to worry about as long as you can make calls. Mine don't even have the logo at all.
cscs3
Until today, I still cannot make calls out nor send sms. I tried calling to my office and home, it does not work. There is not even a sound in the background when my iphone was dialling.
Data works perfectly fine. I wonder whether it has to do with their backend activation because some users can call landlines while some like myself cant.
Not sure which phone you use. If your phone model does not support volte or volte is not turn on. You cannot make voice call. This is currently my understanding.
cscs3
Have to try voice call? The code you mention force a VoLTE option. For selection, but does not necessary means your phone will support it.
cscs3
Anyone get this symptom?
I launch TaoBao and the applicate detected that I am in Australia!
virus2977
Now can call to starhub but M1 and cl still cannot
HARPS_13
Anyone success with using phones with only B40? tried 4 phones only with B40 without B8 band, always no signal.
lohsenglte
LTE Band 40 is kind of limited in coverage mainly because it's used primarily as capacity band, not coverage band.
Sent from Xiaomi MI MIX 2 using GAGT
