TPG Technical Discussion Thread
HARPS_13
Today suddenly signal appear in my area on band 40, able to enable Volte by creating ims apn profile on redmi 4 prime (a china only product), calls to starhub mobile and land lines ok.
renzhen2001
can anyone advise on the steps to set up TPG mobile sim card in iPad Air 2?
No network after inserting SIM card, what to do next? Tks:s11:
atkb84
Anyone using iPhone able to make calls n send sms through the tpg line?
I have set the apn to tpg but only can use data.
galaxyuser
The 4G speeds are very slow omg.
SPEEDTEST TPG >>> MYREPUBLIC
PING 30ms
DOWNLOAD SPEED 5.31Mbps
UPLOAD SPEED 3.05Mbps
Can't stream Spotify smoothly. The speeds hover between 37kB/s to 100kB/s even though I haven't reached 2GB daily cap.
mosmos
High Honorary Member
Samsung A7 - LTE Ok, VoLTE not working (M1 network - LTE Ok, VoLTE OK)
ZTE Axon - LTE Ok
Samsung Tab A 8.0 (2017) - LTE Ok
Mi4i - no service
Update to my earlier list, I just collected version 2 of the SIM card, it works on Mi4i on SIM slot 2
ngbc
Quote.....
These steps are for Xiaomi Redmi Note 4 mtk export set...might work for other Xiaomi phones too.
Go to yr phone dial pad & enter *#*#4636#*#*
Choose Phone info1 or Phone info2.
If you put yr TPG sim card on Sim 2 then choose Phone info2.
Enable 'Turn on SMS over IMS'
Enable 'Toggle DNS Check - 0.0.0.0 allowed'
Next step. Install MTK Engineering mode app from playstore.
Run it & choose MTK settings.
Under Telephony tab, go to BandMode.
Then select Sim 1 or Sim 2 (where you put yr TPG sim card. Mine is in Sim 2.
Then choose 'SET' and go back to Telephony tab.
Go to IMS. Scroll down to 'VOLTE SETTING', select 'CMW500 setting' and
'SET' it.
That's it!
cscs3
Looking at their progress, it looks like they really cannot make it. Coverage really bad.
jianlee
Did some single stream download test from US sites and wow, TPG doesn't cap the speed at all, can achieve max link speed on a single stream. It is even faster than M1 fibre (M1 caps around 11mbps)
My stats:
  • TPG Mobile ... 3512.1 KB/Sec , 28.77 Mbps
  • M1 Fibre ..... 1425.6 KB/Sec , 11.68 Mbps
dryteletubby
I think TPG still tinkering with their setup. I got 500kbps around my house area currently when previously I will get 20+Mbps
