Upgrade old pc - need help
orbea88
Hi, I need some expert help with the upgrading of my old pc.
I am currently using a gigabyte ga-ma770t-ud3p motherboard with, 6 GB Ram, AMD Phenom(tm) II X4 925 Processor, ati radeon hd 5770.
Would like to know if I am able to upgrade to a better processor or what can i do?
Parmesean
Personally, I would recommend you head down to Sim Lim and take a look at some of the older generation CPU, motherboard Combos. Then factor in the cost of a GTX 1060, an SSD, perhaps a new 2TB hard drive, and you would be good to go for at leary another 2-3 more years before needing to upgrade your graphics card.
Koenig168
You can upgrade to a better processor like the 1090T for about $50 to $60 but probably not worth it. Suggest you OC your current processor to its max potential instead.
If your current RAM is 4+2GB then you are running at single channel i.e. half speed. Suggest you change the 2GB to another 4GB ($30) instead and run 2X4GB which would then be dual channel.
Finally, add an SSD (256GB at around $100) for your OS and programs. It will make a lot of difference.
Edit: for gaming, you can consider upgrading to GTX 1050Ti ($210) or GTX 1060 ($350) as your current GPU will not cut it for newer games.
tmfwy
Yours is not just an upgrade
It will be a TOTAL OVERHAUL
If you wish to stick to this platform
An SSD is the best bet followed by changing the 2gb to a 4gb
Psycovirus
There isn't much of a choice but to build a NEW system...
If you provide a budget and what you wish to acheive with a new system, we can help you list down specs...
orbea88
thanks all for your valuable feedback. looks like i need to "overhaul" instead.
have a budget of about $800, just need the motherboard,cpu,gpu,ram, psu(if need to change) not too sure of amd/intel
Psycovirus
May I know what you wish to acheive with the system?
Just surfing web/watching videos or playing games?
Psycovirus
to surf net, check emails, youtube, occasional games such as BF1/Dota
I take it your Seasonic 620W is an M12ii or S12ii?
And you have a 1TB SH HDD, so lets use back those.
Prices are quoted from Dynacore for reference. You may wish to buy from any shop that suits you at Sim Lim Sq or even online.
  • CPU+Mb: G4560 + MSI H110i PRO AC - $230
  • Ram:Crucial 2400 Mhz 4GB sticks *2 - $68*2 - $136
  • SSD:Sandisk Plus SSD 120GB - $80
  • GPU:Galax GTX 1050Ti EXOC 4GB - $239
  • PSU:Seasonic 620W PSU - Reuse - $0
  • Case:Tecware F3 Elite - $49
Total Damage - $734 estimated
MSI H110i Pro AC is itx board with a Wifi so that is nice.
G4560 is a budget CPU which should easily play games like Dota and Battlefield 1
2* 4gb sticks for dual channel mode. You can go for 1 8gb stick and upgrade later if you wish.
Galax 1050Ti should easily push medium/high settings of most games at 1080p
Hope this helps.
