So..the conclusion is Netflix on PC still lousy with viewquest?
No, the conclusion is Microsoft Silverlight sucks.
Not only was Netflix bad, Crunchyroll was horrid too on Freedom VPN 2.0. I went back to UnoTelly DNS and poof, no more buffering..... Viewqwest needs to provide more bandwidth to their re-direction IP gateways.
Recently encountering bad latency in SC2 HOTS. It has been happening for the past 3 days already. Already log a case with NOC but till now no answer from them.
The case ID is TT-00007571. Can someone please check and revert? It's really frustrating because i do not expect this from VQ especially the premium price i am paying. When i was on SH Cable 10Mpbs i never encounter such issue.
I also encountered very slow download speed when download from 33MD...
The latency is almost 400ms to SC2 Bnet servers..
Tracing route to 63.240.104.93 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.0.1
2 2 ms 2 ms 2 ms fnet1-f80-access.vqbn.com.sg [132.147.80.1]
3 2 ms 2 ms 2 ms 202.73.37.254
4 17 ms 5 ms 3 ms tsystems.equinix.transit.vqbn.com [202.73.47.66]
5 177 ms 179 ms 180 ms 217.239.40.213
6 181 ms 238 ms 190 ms 193.158.5.10
7 255 ms 255 ms 254 ms cr2.la2ca.ip.att.net [12.123.30.190]
8 253 ms 255 ms 255 ms cr1.slkut.ip.att.net [12.122.30.29]
9 260 ms 259 ms 258 ms cr2.dvmco.ip.att.net [12.122.30.26]
10 359 ms 360 ms 360 ms cr1.cgcil.ip.att.net [12.122.31.86]
11 360 ms 357 ms 358 ms cr1.cl2oh.ip.att.net [12.122.2.206]
12 394 ms 356 ms 358 ms cr2.cl2oh.ip.att.net [12.122.2.126]
13 360 ms 358 ms 360 ms cr2.phlpa.ip.att.net [12.122.2.210]
14 256 ms 336 ms 256 ms gar1.pitpa.ip.att.net [12.122.107.85]
15 257 ms 261 ms 257 ms 12.122.251.2
16 265 ms 265 ms 262 ms mdf001c7613r0004-gig-12-1.nyc3.attens.net [63.24
0.65.14]
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
Lastly, VQ has yet to get back to me on my free trial of freedom VPN. Was promised by VQ CSO that they will get back to me on working weeks but till now still no answer.
Activation was fast but expectation from premium service was slow and bad.. you still have less than a month to convince me before i start dropping you..
Same for BBC iPlayer. FredomVPN 2.0 --> buffering a lot. Unotelly --> much better.
I joined today VQ community. Applied at their Bukit Timah office which is modern, clean and allows you to test their services. I run few ping and traceroute tests to overseas locations and was rather positively surprised after having close to twice higher latency with SH cable on the same routes (200ms vs 380ms).
I have also requested AppleTV instead of VQTV and there was no problem with that. Installation date was confirmed same day and in my case it takes just one week which is great as I thought all have to wait 3-4 weeks.
The only caveats are:
- $400 deposit for foreigners which I find strange considering all charges are debited directly from credit card and I am sure monthly payments are taken upfront. This deposit remains frozen for as long as you use their services unless you become PR. This is quite strange, I believe the deposit could be held for some initial period of e.g. 12 months.
- lowest plan doesn't come with non contract option.
I chose VQ mainly based on users reviews here on HWZ, also on how VQ staff is active here responding to all questions and their willingness to optimise certain routes if required.
There are several urgent/emergency marine cables maintenance/cuts these few days. Maybe VQ can share more details on them for awareness.
This is something I also felt was strange.
I chose the 12month contract option.
I emailed VQ CS 5 days ago, asked if the $400 would be refunded at the end of the contract period- to which I havent had a reply yet.
If I am out of contract, and being billed in advance per month, on what basis does VQ claim to need a $400 deposit from me?
either VQ are unaware or just simply not monitoring the network load.
my download today hovers ard 100mbps to 140mbps from the usual 200mbps to 260mbps. some files download as slow as 600KB/s even with 16 connections!?
but as soon as i switch over to my starhub 150mbps fiber connection, all my download saturated starhub connection at 150mbps constant!
What happen to the fastest downloads speed for Viewqwest?
The deposit amount will only be refunded upon termination of the service. The deposit still applies on our no contract plans.
"If I'm out of contract- on what basis does VQ claim to need a $400 deposit from me?"
Could it be that
A) you need to return VQ the equipment when you no longer use their services, and there is a chance that the equipment may be out of order?
B) The service is a postpaid service, and you might not settle the last bill when you inform them you want to terminate the service?
C) You move out of the premises and did not inform them you want to terminate the services, and you did not settle the bill for a few months.
Generally, deposits are meant to offset the costs such as spoilt equipment, unpaid bills etc. of course the amount of deposit should be reflective of the likely cost. For example, if the equipment costs only $50 but a $500 deposit is needed, then the deposit amount is not reasonable.
I think most of these are reasonable. Just wanted some clarification from VQ.
RE: Point A. I think this is the most valid. But interested if the deposit is still required if you're using your own equipment?
RE: Point B. Given that you pay a month in advance, I assume that the service is just cut off if you don't pay?
RE: Point C. As above. You pay your monthly fee in advance, so they can cut the service off if you leave without informing them.
RE: Point B and C, I assume VQ wouldn't let the account get more than 1 month in arrears before terminating the service..
Which means the most they are exposed to is a full months fee..
I'd really like a response from VQ about this.
Understand the need for a deposit for foreigners if you're inside a contract..
However, a $400 deposit (that's held indefinitely) if you are paying month to month and not in contract seems excessive and to be completely honest, quite un-warranted.
Look forward to VQ's response. Coming up to 6 days now.
First and foremost it is stipulated in our terms and conditions that we require a deposit from foreigners. Should you wish to commit into an agreement with Viewqwest then you need to agree to be bound by our terms and conditions.
That being said, in most cases the Zhone ONT is provided on a rental basis to customers. Should the customer not return this equipment Viewqwest will be left out of pocket.
We also do not practice the suspension of customers upon failed deductions, as we would like to believe most people would like to pay their bills and the reasons for failed deduction are purely coincidental.
