Vivo X Fold 3 Pro
1982-1994
System
Optimized system stability to improve smoothness
Apps
Optimized third-party app compatibility and fixed the issue where features of some third-party apps do not work properly
More
For more exciting content, please follow the "OriginOS" WeChat account
1982-1994
Camera
Added the telephoto shortcut extension bar to improve efficiency
Optimized the live photo shooting experience with default support for 0.6x–15x focal lengths. You can also enable 0.6x–100x full focal lengths in Camera > Settings > More settings > Full focal length live photo
AI Reader
Added a selection of dialect voices to deliver a more authentic announcement experience
Bluetooth
Fixed the occasional issue where the volume of Bluetooth earphones is low after connecting to your phone
Contacts
Fixed the occasional issue where you cannot search for contacts properly
Origin Notes
Fixed the occasional issue where some features in Origin Notes don't work properly
System
Updated to the May 2025 Google security patch to improve system security
Updated the touchscreen firmware to fix the occasional issue where the touchscreen flickers
Optimized system performance, stability, and smoothness
Fixed the occasional issue of abnormal power consumption in some scenarios
More
Notes
1. This upgrade will not delete or modify your usage data, but it is still recommended that you back up your data before the upgrade.
2. During the upgrade, it is normal for extra power to be consumed and the device temperature to briefly rise a little.
3. After the upgrade is completed, the system will be deeply optimized in the background to improve the user experience. During optimization, the device may experience slight overheating, increased power consumption, lagging, slow charging, or other issues. After 2–3 days, it will return to normal. To speed up system optimization of the device, it is recommended that you charge the device with the screen off when not in use.
4. Installation packages will be automatically deleted after the upgrade is completed. They do not take up device storage space or affect the running speed of the device.
1982-1994
Wah sian, 98% liao
Just about 8 months of usage nia
I charge the battery from 20% to 70% normally some more, is it the downside of si/c battery?
So the capacity drops 1% every 3 months
1982-1994
Besides the rumored fold 7 to have 200MP and same size sensor as vxf3p, the latter still has the best camera setup now even with the release of V5 and x fold 5
1982-1994
This foldable still has a well balanced camera system though the resolution is much below than Samsung's 200MP
Still an all rounder phone
Felt like getting another brand new set and sell the current one, then refrain from software updates
1982-1994
Smoothness optimization
Added Seckill engine support to scenarios such as Trending museums, POP MART mini program, and Watch a game for improved efficiency
Core notifications
Added Damai ticket booking and event ticket reminders. These features allow you to get countdown reminders before tickets go on sale and information reminders before events start, improving the event experience
vivo Sight
Added Real-time conversation memory. Get instant Q&A based on the video stream and get a reply based on recent footage
Accessibility
Added Offline mode to Accessibility calls, allowing you to transcribe the other party's voice without a network connection and announce text to the other party
Optimized the basic user experience in Accessibility mode by solving screen reading issues in certain scenarios
Jovi InCar
Added app adaption for Kuwo Music and Bodian Music as well as sound quality and effect settings
Added the Custom kit feature, allowing you to edit the number of kits and kit layout on your car display
iVideo
Optimized the UI of video app icons for a clearer and more aesthetically pleasing visual appearance
Multimedia
Optimized audio parameters to improve audio playback effects
Core components
Fixed the occasional issue where the battery level is not updated in the Device battery kit on the home screen
Smart sidebar
Fixed the occasional issue where no results are displayed when you search for some small window apps on the Smart sidebar panel
Multitasking
Fixed the occasional issue where the Super Dragging feature does not work properly when you use it on some third-party app interfaces
Email
Added Schedule send for emails, allowing you to effortlessly schedule emails to send based on a set time
Communications
Fixed the occasional issue where call logs are not displayed
Fixed the occasional issue of lagging when you answer a call while multiple apps are running in the background
Home screen, lock screen, and wallpaper
Fixed the occasional issue where home screen icons disappear in some scenarios
S-capture
Fixed the occasional issue where features don't work properly when you take long screenshots in some third-party apps
System
Updated to the July 2025 Google security patch to improve system security
Upgraded the smart charging engine by adding the custom charging limit feature to enhance battery health
Optimized system stability for a better user experience
Optimized power consumption in Tencent Meeting to improve battery life
Fixed the occasional issue where the navigation bar is not displayed properly in some scenarios
Fixed the occasional issue where features don't work properly in some third-party apps in small window mode
Fixed the issue where the system language change does not take effect on some system interfaces
More
Notes
1982-1994
Looks like Vivo x fold3 pro is still the best in specs currently ,no horse run
Best display
Best camera
Best battery life
Best charging speed
Least obvious of the crease
These still apply now but the battery life and maybe the last one
1982-1994
Feel like buying a brand new set and sell the current one,then refrain from software updates as the battery is not as lasting (or just charge the phone till 70%)
But vee gadgets is not carrying it ....
hwarzoner
anyone can install apps from play store? i cannot download tiger, moomoo, dbs, posb, chatgpt etc
restart phone removing cache n data, stil cannot...
Alexz_Hong
it's happening to the few CN phones i've tried too. Tried on CN HyperOS and CN ColorOS, both having issues downloading/updating apps. ¯\_(ツ)_/¯ maybe google changed something that somehow affected phones without full google services.
already tried clearing cache and data from play store, google services framwork etc, uninstalling play store and reinstalling, restarting phone. haven't tried factory reset or logout/login, but a friend on Redmi K80 Ultra already tried that and still was the same. :ROFLMAO:
additional info: some times seems like randomly if retry every now and then 1 or 2 apps will be able to update somehow. toggling wifi off and switching to mobile data if it's stuck, sometimes will somehow work also.
hwarzoner
omg thank you bro i switch on my wifi and mobile data together thats why cannot download apps from google play store, once i disable wifi and only on the mobile data i can download now. ty ty
rinchan22
best solution for me was to use protonvpn (found this info on reddit).
1982-1994
Just bought a used set non pro version, like new and the max battery capacity is still at 100%, for $900
Reason being instead of getting x fold5, sd8g2 is efficient than it's successor
At least the standby won't drop 1% every 1.5h like the pro, it drops every 2h, 4% overnight ,quite acceptable
Play with it first
chari-men
Play with it first
Wah you downgrade from Fold 3 pro just for battery life ??
