iamnagel
- Jul 19, 2010
Pre-order from where?I’m pre-ordering one
The camera really look insane
sometimes may have some problems with some apps if using china set with china rom.Anyone know if the china rom itself can install Google things and use GMS? Currently in china quite tempted to buy one
But, hard to predict.
If not keen to troubleshoot stuff, better to avoid.
No such issues. OriginOS has a settings to enable Google Services. I used S18Pro, X100 Pro before. Only thing is you need to download Google Play Store apk yourself. In fact OriginOS 5 is much advanced than FuntouchOS.Anyone know if the china rom itself can install Google things and use GMS? Currently in china quite tempted to buy one
How come X200 mini 16gb+1tb ($1,120) is cheaper than 16gb+512gb ($1,355) version?
Is about 80. There are 2 options for 16+512, which I think one is not correct.
What is this 3d lut?How come X200 mini 16gb+1tb ($1,120) is cheaper than 16gb+512gb ($1,355) version?![]()
Surprised the mini doesn't support USB 3X200 mini is as good as X200 Pro, the telephoto aperture is bigger than the pro version despite the smaller sensor and shorter focal length, the other downside is there is no 3D LUT import in mini, not sure why they take out this feature![]()
still got a few other differences. as someone mentioned, USB 2.0 port on Pro Mini, only X200 Pro gets USB 3.2 (with DP support). a few other difference i noticed on their specs page, screen on mini is 1-120Hz compared to 0.1-120Hz on the Pro, the resolution for video is a bit lower at up to 4k for regular video, 1080p for slow motion on the mini, 8K and 4k for slow motion on the pro, fingerprint sensor is optical fingerprint sensor on mini, ultrasonic on the pro, pro has something listed called "多光谱传感器" (multispectral sensor) which isn't listed on the mini. but otherwise, it's probably the most feature packed android phone we've seen so far? most of them probably aren't a huge deal, but USB 2.0 with seemingly no display out is a bit disappointing for a phone this price. if got DP support like iPhone 15/16 at least a bit easier to swallow...X200 mini is as good as X200 Pro, the telephoto aperture is bigger than the pro version despite the smaller sensor and shorter focal length, the other downside is there is no 3D LUT import in mini, not sure why they take out this feature![]()
